skajohyros
Not my diagram. Just used it for my build as it was pretty straightforward for a beginner.
Have a good day.
Have a good day.
Pin 4 should read about 12VDC, which should be the heater voltage across tube pins 4 and 5 (Ground). However, "12VDC" is an estimate based on the Dsavitsk-The-Equalizer mod for the 12AU7. You may not get that voltage, depending on the resistors selected and their tolerances. If it's higher, it's possible you've burned the tubes out prematurely.Good to see you're still around Tomb. Bear with me as I'm almost clueless.
I'm using the 12au7 layout. Pin 4 is connected to source. What should be the voltage readings here?
Also, non grounded ends of R4,R10 are about 14v.
Are my original MOSFET readings ok?
I'm confused.
Basically, where should I be checking for voltages and resistance and what are the expected values?
Cheers.
