the_equalizer
- Jul 5, 2009
This is my understanding of what increased cap values does in the MSSH.
In the C3 and C5 positions higher value caps will extend the lower end frequency response with lower impedance 'phones. As mentioned in another post some have put 1000uF caps here. The only possible downside to this is that this will also increase the strenght of the turn on/off thump.
Higher values for C1, C6 will improve the power supply filtering/decoupling thus producing a tighter, less sagging sound in loud transients.
cheers!
Originally Posted by SteveC89 /img/forum/go_quote.gif Ok, so I am about to start my build, but I just realized I ordered 220uF capacitors instead of the 150uF specified. I noticed in the original BOM notes it says any value > 150uF. I was just wondering how the higher value caps might effect the sound. |
cheers!
