I feel like interrupting again, but I just couldn't waite sharing my succes
I slid the amp back in the case and haven't yet screwed on the front and backplate, but as my DC offset was only 1.2mvolt after half a minute, I plugged in my HD650.
An amazing little amp
I understand it when some say that the caps need a burn in period because when I left it running for about 2 hours or so I recongised quite bit of difference from the first few minutes.
Allthough I do recognise that the right channel is significantly louder (not very very much, but you really feel it though, subtle). It becomes really clear when I compare it to my headphone straight from my ipod touch. I have set my rockboxed ipod for 13% more left channel volume to temporary kinda equalize them. Is there any way I can internally fix this? Because I don't really plan on using this solely with rockboxed ipods
Tomorow I'm gonna try some 'pinknoise' on it
, so I can get a more accurate idea of how bad the imbalance is. I also read that I should try switching the tubes, or see if the effect is less when the pot is turned up more (signs of an imbalanced pot, I read). I'll be switching the tubes tomorrow (If the channel switches with them, I'll sue my spare set of tubes, so no worries there). Allthough, as far as I improfessionaly tested it, I can't really say that the effect doesn't lessen when I switch from 'low ipod volume, high pot volume' to 'high ipod volume, low pot volume', so I don't think it's an imbalanced pot.
It's as if, when normally the singer is in the middle of my head, it's like as if he shifted more to the right.
Is there any other test I could perform before casing up the amp? And is there a way to internally fix this (I heard of adding a resistor to the right channel to balance it, but yet again, I should know the exact grade of imbalance), if so I'll wait before boxing up the amp
BTW: I forgot to say, could it be the cable? I'll explain why. Right now i'm not having a mini to RCA cable at hand so I'm actually using like 3 crappy cables to comensate: First I got an RCA cable from the television (male on each side) connected to the amp. Then I got a selfmade 'female RCAs to female mini connector' to connect to the first cable. As las I got a mini interconnect (two times male) to make the last step towards my ipod.
I was making a (yep even trying to braid it
) a mini male to RCAmales with some generic parts though, when I came to the genial idea to just use those 3 components for a while, to try the amp out. So maybe it's that.
Also, are there any 'professional' ways to test the imbalance? I'm gonna try the pinknoise demo, switch the tubes.. but that's about all I can imagine.
Thanks
Dries
AND A HAPPY NEW YEAR EVERYONE (4 hours to go here though
)!!! You guys made my holiday
My best wishes, a good health, lots of luck and have fun the next year!
*draws a partyhat*
