nullstring
- Oct 24, 2008
you should try switching the tubes, and see if it switches then.
Originally Posted by tomb /img/forum/go_quote.gif Actually, it's possible that one of the tubes developed a short. If the plate connections short with the heater connections somewhere inside the tube, then the heaters may see 48V. Just a guess ... but it might explain what you're seeing. |
Originally Posted by kuroguy /img/forum/go_quote.gif He did say that the problem does not follow the tube. That would usually rule out a bad tube. |
The problem does not follow the tube. |
Originally Posted by mlau /img/forum/go_quote.gif Sorry for the dumb question. What is the part number for the volume knob on the Beezar kit? I really like the minimalist look of the knob, so I'd like to know how much it costs/where to get it. |
Originally Posted by Nonchalance /img/forum/go_quote.gif I got some measurements. 48V on MOSFET pin 2 both sides. 48V between R1 and R2, 48V between R7 and R8. 21.55V on tube pin 3 left, 48V on tube pin 3 right. So I guess the right side is messed up, but the tube on left isn't lighting up and I'm not sure how to fix the voltage problem. Did I kill the tubes? |
Originally Posted by Nonchalance /img/forum/go_quote.gif I definitely wired to pin 3. How do I test if the MOSFET is shorting out? |
I can't get a resistance reading on 3-4 on either of the tubes. I guess I blew one and the other was damaged during shipping. Well this project failed, haha. Is there another way to test the rest of my circuit without the tubes? I want build it right at least. |
Thanks for all the help guys. I really appreciate it |
Originally Posted by kuroguy /img/forum/go_quote.gif turn it off before you waste that really bright tube. you are running 44 volts through a 19 volt filament. I bet the tube won't last more than a few minutes at that rate. |
Originally Posted by hitman47 /img/forum/go_quote.gif OK, I already managed to screw my amp up again... I finally got the casing more or less done and was running it with my PC as source, so I lifted it onto my desk which has a massive metal frame and there was a huge spark from the casing to the metal frame and now only one tube glows when I turn it on and there's no sound coming out at all. Any ideas as to what might have gone wrong? |
