Fitz
- Nov 12, 2005
The plate is normally run at around 100V (max 300V), but runs at half that in the SSMH. The filament is absolutely not rated to 100V, and running it above 19V is a very good way to damage it. Even going only slightly over the rated filament voltage will rapidly diminish tube life.
Originally Posted by ethan961 /img/forum/go_quote.gif I believe it is rated for 100V, so there should be no worries. TomB didn't warn me of it (I am having the same problem) and I believe it is on one of his sites at DIYForums.org. The tubes normally run at half voltage, so I wouldn't be worried. I can't currently check the resistance on my amp but I still cannot see anywhere there might be a short. I might get some pics up when I get home tomorrow evening. |
