tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
I'd have to say that if the problem followed the tube, that's pretty conclusive. Some of these tubes (not ones I've tested and rejected) have intermittent shorts. I've seen a few that changed with a little shaking.
. Just enough metal was flaking off in areas to come into contact with the pins inside - that doesn't mean you'd have to see it for it to be shorted, though.
Originally Posted by kuroguy /img/forum/go_quote.gif First of all, thanks to the guys who put the kits, cases, and boards together. Group buys are not a way to get rich. Especially when you are machining cases by hand. Now, onto my problem. My SSMH has been working flawlessly for the last year. I recently relocated and when I set up my amp at work the left channel had a 60 cycle hum that gets louder when I move my hand near the left tube. if I touch the tube it is the loudest. If I ground my hand to the casewhile it is near the tube the hum goes away. In face, even a paperclip that touches the tip of the tube and a ground point on the case stops the humming. I switched the tubes around and the hum followed the tube. The room it is set up in has an audible 60 cycle hum without the headphones on. Is this a bad tube or a grounding issue? I suspect some aluminum foil around the tube should solve the problem, but that wouldn't be too elegant. Any comments or suggestions? |
