I just finished my PCB-based SS (sorry Tom for getting a proto PCB then waiting half a year to build it). As I wrote a few posts above, I top mounted the 4 electrolytic caps as my Cerafines were too tall. This led to an accident while drilling the top holes, and after much head scratching I managed to salvage the case by carving a large space on top with the Dremel. It's not perfect, and I had to move the fastening spacer below the board, but at least it does not look like a bomb went off inside the case.
On hindsight, I might have just let the tube sockets protrude a little bit more on top, which would have allowed me to mount the board on the second slot, gaining that extra bit of space below for the caps. Or I could have used a slimmer case, with the caps mounted on top as they are now.
I also had a bit of a scare as when I plugged the amp I had no voltage anywhere, just 3V on the power switch. After some measurements I found out I have a defective switch, what are the chances of that? I bypassed it and the amp powered up fine.
I tested it with the iGrados and there's a bit of noise at high volume (which curiously is still listenable and not extremely loud) I then switched to the Yamaha HP-3, and the SS is barely able to drive them to listenable volume. My two other SS built using Pete's original BOM are louder, so I guess I'll have to remove something.
Will it be enough to remove R14/R15 leaving R16/R17 in place? I had a few accidents with my other SS and a couple Alien DACs, and I seem to remember R16/R17 offer some protection for the source.
