MHDT Havana DAC
May 10, 2014 at 11:51 AM Post #2,446 of 2,680
If anybody is curious ... here is a shot of the new Stockholm v2 DAC internals.
This is the board where they have bypassed the PCM56K's internal OPAMP section:
Cheers.
May 18, 2014 at 2:17 AM Post #2,447 of 2,680
I see already some Black Gate and V-Caps there
...Oscon's are the best for the digital stage section, no doubt.
@Joel,
when you start a modding with this beauty?
May 20, 2014 at 1:25 PM Post #2,449 of 2,680
Sure you can. However if you already got Audyn TC on output I would try more neutral caps elsewhere too avoid a too typical result but Audyn TC are great ones so you would not be wrong anyway.
May 27, 2014 at 8:35 PM Post #2,450 of 2,680
I am doing some more upgrades on my Havana and I am ordering some Schottky diodes from PartsConnexion. I have read through this thread several times but can't seem to nail down the exact type to order. They have several types to choose from:
1A 600V
4A 600V
5A 1200V
6A 600V
10A 600V
10A 1200V
Price ranges from $1.50 to $24.95 each. (I hope the cheaper ones are the best!)
Which of these is the correct spec? I need 8 of them.
May 27, 2014 at 8:41 PM Post #2,451 of 2,680
1A 600V
4A 600V
5A 1200V
6A 600V
10A 600V
10A 1200V
I used 600V 2A from Mouser:
http://www.mouser.com/ProductDetail/Cree-Inc/C3D02060F/?qs=D3QG1iK7FqhDcfNooQXNgA==
That value is referenced as viable somewhere in this thread.  Works for me.
May 27, 2014 at 8:51 PM Post #2,452 of 2,680
If one were to upgrade JUST the output caps of a Havana DAC? What would you all say would be the best choice and why?
Thanks...
My vote would go to Rike Audio S-Caps.  The depth of detail and separation and dynamics are incredible, and the tone is very natural as well.  The details do not come in the form of harsh, overly-highlighted highs, as some might fear from such a description.  It is a very well-balanced cap.  Exactly the injection the stock Havana needs, in my opinion.
May 27, 2014 at 9:11 PM Post #2,453 of 2,680
Thanks for the Schottky info. Will those Rikes fit into the Havana? They look huge!
May 27, 2014 at 9:32 PM Post #2,455 of 2,680
I was thinking of the 2.2uf for C33 and C35. They are 40mm X 40mm X 26mm.
May 31, 2014 at 12:41 AM Post #2,458 of 2,680
I agree, Eugene.  S-Caps are very neutral and create the feeling of capacitors disappearance (without caps)...Instrument and voice tonal colours are very slightly enhanced over no cap. I think, they are the best for Havana in this price category.
They works very well in this DAC! If I had more money, would have changed all film capacitors with Duelund Cast PIO. If Rike sounds so good, I imagine how would sound Duelund. Would be close to perfection, IMHO..
 ... however, Rike & V-Cap CuTF = audiophile delight.
May 31, 2014 at 4:11 PM Post #2,459 of 2,680
For some reason my Havana is giving me the red light and blue light at power up and won't go beyond that. It has been fine in the past. Can anyone tell me what the red indicates? Digital signal or electrical issue?
May 31, 2014 at 6:22 PM Post #2,460 of 2,680
Turns out it was a digital issue. One of the contacts on my spdif cable came loose. Soldered it back on plugged in and green light is back!
