LionelH2
- Feb 6, 2007
Thanks one more time, I will do the .22uf, 100uf, and 470uf upgrades, then done.
I just today received a review sample of the newly released MHDT Stockholm DAC ...
So in a few weeks I should have a fairly extensive review done in comparison to the Havana...I'm doubtful that they will perform that much differently but I *am* curious as to how the higher bit depth/resolution capabilities of the Stockholm will sound.
If you haven't read about it yet, here's a link to the Stockholm info:
http://aloaudio.com/stockholm-dac-from-mhdt-labs.html
FYI.
Rock.
.j
I look forward to your review of the new Stockholm. I was just about to buy an Havana and just found out about the new Stockholm now I am thinking I will get the Stockholm but I haven't seen any review of it yet. I am hoping it may be a nice upgrade from the Havana.
Mundorf is more punchy then FT3. I'll probably stay with Jupiter. Personal preferences.
I installed the Mundorf .22UF yesterday and let it burn in overnight. WOW. Amazing!!!!
Fortunately the house is not on fire ,
I temporarily installed the R-core transformer, I'm shocked by the sound improvement,
Mundorf .22 upgrade is nothing compared to R-core.
This baby causes jaw dropping effect. WOW, EVERYTHING is much improved,
(separation, air, timbre, kick, etc...)
I'm extremely close to real performance quality.
I was to stop upgrading the DAC, NO WAY !!
Frankly speaking the MHDT could source a better transformer for this DAC. The stock one is very poor.
This is one of the most important upgrades for Havana in my opinion. !!!!!!
Lionel, I'll give .22 Mundorf silver/gold a second chance next time.
Where did you source the transformer? Looking forward to see how you install it physically. Are you planning a separate chassis?
What are the pros/cons of these tube-DAC hybrids over a purely solid-state DAC? Including the advantages a solid state would have too please. (I am not trolling, if you fear it may start a troll war, then please just pm me the answer.)
Loserica,
You can replace all Nichicons with Elna. (Havana will sound quite different after the mod but nobody knows how),
I suppose it should sound better, but you can achieve much more with Havana's construction mixing the caps.
Vcaps OIMP are good caps and only good, but if you're looking for extreme sound quality,
they are not perfect solution.
Vcaps CuTF and TFTF are extremely expensive ( Vcaps CuTF 1uF - $486 each - ($2000 output set), Vcaps 2uF TFTF $459 each($920 set)), I bet they are not better than Mundorfs top of the line which are cheaper - $100 each ($200 set))
I found the Havana had some key caps which should be replaced with care.
Digital section's caps, powersupply's caps, some of the foil caps etc....
(hundreds moves to achieve satisfaction)
Next weekend I'm replacing the stock 0,22uF foil cap with:
Candidates to that place are:
Mundorf silver/gold,
FT-3 Russian cap,
Jupiter yellow vintage tone.
Will send photos and my impressions about that operation.
