Just a quick note comparing the SE and balanced Havanas (and break from all the tweaker noise : ))
I was looking for info on here about the differences between the SE and the balanced version of the Havana and in the end ordered the balanced version blind from Aphroditecu39 then AB'ed the two outputs. Here's what I found: in this case, balanced is better. I'm using a Primare A30.1, which is truly a balanced mono design, with Audioquest King Cobra in both applications (SE and balanced), so YMMV depending on your amp/integrated and cables, but here the balanced Havana is far quieter than the SE. The background is significantly blacker, the overall image is fuller, clearer, and without grainI by no means would have thought much of the difference if I hadn't heard it. Anyways, I'm impressed and I wasn't really prepared to be. I'd thought of it as a harmless experiment, thinking if the difference was negligible I'd just sell the balanced version and keep my SE Havana. But I'm keeping the balanced version. The difference in the end is significant enough to me to warrant the extra cost. Anyone else have any experience with the Balanced yet? Just curious what others' experiences have been like.
