ToroFiestaSol
- Aug 11, 2015
@Bastianpp It depends on what do you consider a legend, if that is the bright, closed in, plastic Focal house sound...then give me ordinary headphones!
I do not currently own the Focal Utopia. Do you? (I do not see it currently listed in your profile). The Source AV not too far from me has a Utopia for audition as well, and I can listen to them both back to back, volume-matched then. You are more than free to judge the Empyrean (and any other headphone) based on your pricing reason(s).First one, do you have the utopias?, if you said "through memory " i think no.. and make a comparasion by a short listening in the past ( with the exception if you have both headphone in that moment of comparasion) its really hard to make a good comparasion in that way
And i can't see the impressive technical abilities of this headphone ( like the speed and details of utopia ) in this thread by opinions of the people here.
This is a 3500 usd headphone, it has to sound like a legend.
Best regards
i don't like the '' little bright '' headphone, i never heared it , but many people said is very impresive in technnical abilitys of speed and detail, i'm talking about the technnical abilitys no the FR@Bastianpp It depends on what do you consider a legend, if that is the bright, closed in, plastic Focal house sound...then give me ordinary headphones!
sadly no, my gear are: Ether flow open, beyerdynamic t5p mk2, burson cv2+ and iBasso dx200.I do not currently own the Focal Utopia. Do you? (I do not see it currently listed in your profile). The Source AV not too far from me has a Utopia for audition as well, and I can listen to them both back to back, volume-matched then. You are more than free to judge the Empyrean (and any other headphone) based on your pricing reason(s).
Take care.
Or a Stax.First one, This is a 3500 usd headphone, it has to sound like a legend.
as i said '' i'm talking about the technnical abilitys no the FR '', the graph of focal clear is more interesting to me, but again FR =/= technnical ability, the technnical abilities are the diference between 2 headphones with similar FR but different price, like 100 usd and 4000 usd.What is speed and detail to you? If the erroneus frequency response of the transducer makes, for example, a piano sound like a guitar, then we have a serious problem with the transducer...the Utopia has a very uneven treble and a upper midrange bump, plus an extremely uneven impedance. Honestly, I think that you confuse treble peaks with speed and detail. If you want to play the "many people said" game, then let me tell you something, the impedance of the Utopia is so uneven that many people use it with tube amps with a high output impedance, which results in a severe change in the frequency response of the Utopia, raising the bass by several db...it's so incorrect and claustrophic sounding that people prefers to hear it that way instead of how the designer intended it to be used (0 ohms output impedance amplifier), because the added distortion and the bass bump hides (but does not eliminate, let's say it makes it less obvious) the plastic sounding character of the headphone and widens up the claustrophic soundstage a bit.
Here you have a graph showing you how much it changes with an amplifier with an output impedance higher than 0 ohms.
https://diyaudioheaven.wordpress.com/headphones/measurements/focal/utopia/
If that's your concept of legendary headphone (so legendary that you don't have one), then, let me repeat, give me an ordinary headphone!
people said the stax Sound light in body and lack impact... there is a problem with '' the people said '' i know, but not all live en USA.Or a Stax.
Obviously boost in treble can show more the detail, but it's artificial.
sadly again, i can't tested the headphone, the only way is buy it an see comment/graph.
Regards.-
I agree.
I just sent this period to the NSA labs for analysis. It may hold more encoded/invisible information than that obelisk in "2001:A SPACE ODYSSEY"
