project86
- Feb 21, 2007
I have a question not directly related to Meze Empyrean but with planar drivers.
I never owned any Planar drivers previously.
I always had Sennhesier or Sony with me. As dynamic drivers i know that Output impedance of amplifiers has impact on the Damping factor etc. Also the impedance of dynamic drivers vary with frequency range.
Does the output impedance of Amp have similar impact on Planar drivers. Do i need to worry about 1:8 rule for Planars as well like that of dynamic.
I am asking this since I have HD 800s and 600 and I plan to own good Tube amp in future which may have higher impedance. So can i use Meze with those tube amp or it will be total mismatch.
currently i have Liquid Platinum which is hybrid and hence no issue with impedance and same with Chord Mojo. But i also have Schiit Valhalla 2, which has output impedance around 10 in high gain.
sorry I don't know how Planar Magnetic drivers work
Most planars have essentially ruler-flat impedance, so output impedance isn't important. Damping factor seems less of an issue as well, though not completely irrelevant. Basically I hear tighter, more "accurate" bass when driving planars from an amp with low OI... but high OI tube amps can still sound good enough in other ways where I don't mind their slightly less tight bass.
I will be trying Empyrean with my Cayin HA-1A mk2 as soon as I find the time. It has selectable OI but the lowest setting is 8 ohms, so we'll see how that does. Unfortunately I just sent back my review unit of Cayin's monstrous HA-300 right before my Empyrean arrived, so I never got to use that pair together.... I bet it would be magical.
Thank you.
By the way, I also want to thank you for all that reviews, you have made. I`ve read a lot of them, very interesting and useful reading.
You are welcome! Thanks for the kind words, I appreciate it.
+1 to you too!
