ninjikiran
- Jul 1, 2009
hey, has anyone tried using a high-end usb cable and know where if it will indeed make the sound coming through the usb port 'better'?
i know that many use toslink cables but from what i understand a toslink optical cable capable of achieving a high-grade audio standard will usually cost much more.
also, does anyone has the opportunity to try both the opa627 as well as the lt1364cn8 and lm4562na op amp?
I install opa627 both at the dac and headphone side. the resulting sound is smoother and cleaner at the expense of some details so i wonder if I should change my op-amp to lt1364cn8 and lm4562na. The only thing I dislike is that they are all sold in pairs. =(
or shall I wait for the new upcoming headphone amp?
Some people will argue about it but lets face it, Toslink COAX and USB are all the same in terms of transporting audio. Don't believe the placebo of digital cables changing sound quality between high and low quality.
Coax is more finicky, I used a cheap RCA cable to test it out. Sound quality was the same as the cable I use now but it was very thin and poorly insulated so it did result in some drop out at random times.
Sound music file on your computer technically becomes "audio" when it hits the DAC and its converted into something analog that your headphones can translate into audio. From there on it is static 1's and 0's and 1's and 0's is not something you can really mess up unless it is done intentionally. The DAC and the chosen opamps are the only place where real coloration can occur.
At the same time on my machine using USB is not advised because windows uses a standard driver which locks it out at 48khz meaning any song going out of USB needs to be resampled in some way shape or form which is a lossy process(whether or not the differences in SQ is worth using USB over another transport is up to you). Using either Toslink or Coax from my sound card as a transport to the DAC provides a lossless(or variable-less) transfer to the DAC. Mainly because my sound card can be turned into a bit-perfect transport but I don't know if the onboard ones can.
I use the LM4562 opamp on my headphone output and it works like a charm, in terms of SQ from default it sounds basically the same. Difference being the default opamp has sort of a higher pitched sound on certain syllables like s so it is less fatiguing on my ears over time.
