burdie
- Oct 24, 2013
Thanks for your info. Yes I got Mini-I Pro Ver 1.2 while in Config menu
Hi, I just received Mini-i Pro and believed it loaded with latest firmware (ver 1.2 shown on config menu). I got few question/problem to ask expert here about it
(1) My Mini-i Pro installed as mini-i in Win 7 (when installed driver the USB device pop up info shown mini-i installed but mini-i pro failed). Just wonder anyone installed it as mini-i Pro?
(2) The bottom chassis printed with Mini-i with no 'Pro', is this normal? However, the serial number same with the serial number printed label on the box which stated mini-i pro. Even on config menu got setting on PCM and DSD so I believed it is pro version, but why the chassis not printed with 'Pro'? just need the confirmation on yours.
(3) Setting it on foobar by installing all required driver/plugin, unable to playback DSD until i changed DSD playback method. Below is what I got on various DSD playback method under foo_dsd_asio v0.7.1.2
Asio Native : unrecognised 44khz sample rate
DoP Marker 0x05/0xFA : finally shown DSD 2.8 on my Pro
dCS Marker 0xAA : shown rate of 17xkhz
exD Marker : shown rate of 17xkhz
Is DoP Marker the correct playback method and the SQ has no different to Asio Native?
If you have better configuration or other playback software please let me know, preferable with detailed guide.
Thanks
Hello Everyone,
Im new to this forum. After readed this thread, i decided to purchase matrix mini i pro because of i can use my AppleTV remote control to remote this Dac, I already set the REMOTE option under configuration to MC377 but it doesn't work. Anyone work with your remote control?
Thank you very much.
You can use stock remote control to remote this DAC .
Yeah, I know, but i got too many remotes on my desktop, TV, logitech 5.1 remote, BD Player, .... anyone help?
Thanks appreciate !
Hello Everyone,
Sorry, I don't have any iDevices, but both of my units worked with the included Pro controller. Have you tried the Pro controller to make sure it isn't a defective IR receiver?
Happy to report, at long last, I've received a replacement for my defective Mini-I Pro and the new one does not have the problem my previous had, where it would stutter and volume shift erratically at high PCM sample rates (352.8 and 384). If you still own a unit with this defect get it replaced now!
Yes, it did happen in DAC only mode, and yes it actually did still shift volume in that mode. You can upsample files via JRiver or other playback programs to test your Mini-I Pro.
