ev01ut10ndt
- Jan 30, 2007
Thanks for the explanation. I'm not an engineer at all and had no idea what the things on the datasheet meant. I would appreciate your input as to how the class A biasing sounds with the OPA627 from JTam. Did you get everything prebuilt or just the OPA itself or with the browndog adaptor?
Take a look at the datasheet, It explains the difference between versions as well as has drawings of each difference.
Difference in how the chip is packaged, either as a solder on, through pin, or metal tin. This affects the temperature and voltages ranges it can tolerate.
Other difference is how individual chips are packaged for loading into industrial machines.
When most people refer to the OPA627 they are either referring to SOIC versions or PDIP versions.
