swmtnbiker
Previously known as dpippel
Haha that's my sister's room, it had better lighting than my room. Although i have nothing against cute little yellow pillows lol
The pillows really tie the room together...
Next time i take pics i think i should have the pillow in front and the amp in the background
Am I such a quiet listener or something by having the amp on 10 'o clock at most at 0dB gain, I mean, I use it qith a Q701, which aren't the hardest cans to drive, but not the easiest either..
Try setting the switches to 18 dB or 20 dB gain.
The volume should go WAY up.
If the volume goes WAY down, you have the switches reversed and you have NOW set the gain to 0 dB. Just like everyone else does when they first get a Matrix M!
I just remembered that i have a really old low quality dvd player so i hooked up my m-stage to it and it works! The dvd player doesn't even play any music CDs so im currently playing a copy of I Am A Legend haha, audio only no video. All i can say for now is that it sounds very nice Im pretty sure the dac in this player is terrible though.
You're using the DAC in your DVD player. It's what produces the signal amplified by the M-Stage.
I use one input channel on my M-Stage for my Blu-Ray player.
Imo the stickers arent wrong on the M-Stage, the switches are white and the white part of the schematic therefore indicates where the switch should be, not the black part!
No I actually had it right the first time, if I invert all the switches I can't even put it higher than 8 'o clock at +20dB! Whereas with unity gain I won't go higher than 10 'o clock.
Seems I'm a quiet listener or something, and I was thinking I was one of those persons who had trouble finding the ultimate balance between safety and intensity in terms of volume
