I have yet to hear the LCX but do have the original Liquid Carbon and if it close it is yes a great amp.
Massdrop x Liquid Carbon X Discussion
Focux
https://www.massdrop.com/buy/massdrop-liquid-carbon-x-sdac-dac-amp
apologies if off topic but any idea if the dac on this is better than the Mojo?
am waiting for the THX amp to pair w mojo but if the sdac or cth + sdac configs are better than using mojo w thx then i guess no point waiting..
eeagle
I have a lot of respect for the Grace and Cavalli designs and sound, this is an excellent combo IMO. The SDAC can be used stand alone or w/LCX making for a very versatile rig. The SDAC AKM AK4452 is limited to 24 bit/96 kHz which may a deal breaker for some, but I personally have a tough time actually telling the difference between 96kbps and higher rates in AB testing.
Pure spec wise the Mojo 789/THX is the better combo, but you won't be getting the fun colored Cavalli sound The Mojo is really more of a portable device and my current DAC of choice is the SMSL SU-8 providing balanced output for the 789/THX.
clerkpalmer
- Dec 16, 2015
Hi just grabbed the non Sdac version of this today. I’m going to use my modi3 and Loki with it. Any connectivity issues? I would plan to use the balanced cable for my headphones. I’m reading something about a fully balanced DAC which I don’t understand. Just want to make sure I can plug and play the modi to this and still go balanced on the amp. Tia.
eeagle
You will be fine the balanced output works with either balanced or single ended DACs; in fact the SDAC version is single ended DAC.Hi just grabbed the non Sdac version of this today. I’m going to use my modi3 and Loki with it. Any connectivity issues? I would plan to use the balanced cable for my headphones. I’m reading something about a fully balanced DAC which I don’t understand. Just want to make sure I can plug and play the modi to this and still go balanced on the amp. Tia.
^Correct- the Liquid Carbon will take an unbalanced input and phase-split the signal to run it balanced through the amp to balanced output.
CoFire
- Dec 5, 2015
Can somebody verify the SMPS Output on their power supply brick? Looking for voltage and amperage. I want to be sure I didn't swap bricks. Most of mine are labeled but I didn't get around to labeling this one.
Thanks in advance.
Thanks in advance.
donato
Thanks in advance.
30V, 1.25A
i am considering to buy this, my source is DAC on UD-301 (TEAC) and balanced out to the amp, and pair with HD650, LCD 2C, and a custom IEM, playing genre mostly trivium similar musics, and totally dig hearing drum rolls
spyder1
- Dec 31, 2014
Senheiser HD650 w/ balanced cable, IEM used w/ SE output should give you EXCELLENT SQ. That is how I use my Cavalli LCX.
but there are a lot of concerns on the QC consistency that im concerned tooSenheiser HD650 w/ balanced cable, IEM used w/ SE output should give you EXCELLENT SQ. That is how I use my Cavalli LCX.
The LCX made by Drop has been stable, super-consistent and we back it if there are any issues...but there are a lot of concerns on the QC consistency that im concerned too
abvolt
There's not been issues with mine I've had it since release this is an excellent sounding amp..
My unit was one of the earliest production units. Almost immediately after i received it, one of the SE inputs did not work. I hv been using it with balanced inputs since. Did not want to incur shipment costs to repair as i live in south east asia.
im uncertain, its either this or the jds atom, but i think atom might be the better path, or not
you are Singapore, i am malaysia, same scenario concernMy unit was one of the earliest production units. Almost immediately after i received it, one of the SE inputs did not work. I hv been using it with balanced inputs since. Did not want to incur shipment costs to repair as i live in south east asia.
