Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Aug 30, 2023 at 5:46 AM Post #8,611 of 9,551
I received MeetAlice yesterday (MMCX & 4.4) and has about 20h burn in now. I gave it a try with my FiR VxV but I find that the low end is seriously lacking compared to stock cable (SPC). More burn in needed or just a bad match?
Edit: after another +10h things seem to be improving.
Aug 30, 2023 at 10:49 PM Post #8,612 of 9,551
Don't know if this is the right thread to post this, But anyone got recommendations for Sennheiser HD6x0 series? I have used some generic ones and a Hart cable and a 200usd expensive copper one in the past.
Just looking for a cable that doesn't change the sound too much. All suggestions are much appreciated.
Sep 6, 2023 at 2:03 AM Post #8,614 of 9,551
Hi, does anyone have any recommendations for lightweight SPC cables from XinHS etc? I have a pair of Softears Studio 4s, and while I like the thin design and minimal/lightweight braid, the stock cable is just a bit short for my current desk setup (thus, I would contact the store to get a~1.4m cable made). It would be nice to have it in black so I can keep the all-black aesthetic, too.
I'm OK with spending in the $50 - 100 range, but would prefer something on the lower end of that spectrum. I might be willing to spend more eventually, but I'd like to keep my expenditure well under $100 for now.
Phone is out of commission so I can't snap a photo, but Super*Review's review shows off the cable pretty well, I think.
(Much later) EDIT: I'm looking for an SPC cable just to try it out and see if I can perceive any changes in sound. I know the stock cable is copper.
Sep 7, 2023 at 4:50 AM Post #8,616 of 9,551
Hello, I would like to ask for some help. I want a cable for IEM. I read a lot here but I can't decide. Can you recommend something under $50? Thank you very much in advance!
For which IEM?
What changes should the cable give?
Sep 7, 2023 at 7:10 AM Post #8,617 of 9,551
Was what I was replying to above, but here it is again:
https://m.aliexpress.com/item/1005005357155557.html
Good price at the current sale. I bought mine at the last big sale but now it’s almost $10 less than that.
Edited to add: slightly more detailed impressions from earlier in this thread - https://www.head-fi.org/threads/low...ng-for-buck-cable-thread.891911/post-17638312
Is this store more or less his bespoke or made-to-order cables? Are the "sales" their actual price or should I snag one before it goes to the triple digits?
Thanks! Sorry if this is well known or not.
Sep 7, 2023 at 10:35 AM Post #8,619 of 9,551
FENGRU Blue 8 Share 240 Cores Silver plating single crystal copper Wire
https://www.aliexpress.com/item/1005003071741419.html?channel=twinner
Better than I expected, just a solid good budget cable. Look good also with fake Furutech hardware.
Sep 7, 2023 at 12:33 PM Post #8,620 of 9,551
The price right now is just about right, only a few dollars more than I paid for mine when it just launched. They reduced it by maybe 10-15% at the sale that ended just a few days ago so you could wait for the next one if you’re not in a hurry.
The store takes custom orders as well. I liked this cable so much I requested for a custom made 8-wire version, but its price kind of disqualifies it from this thread :)
Sep 7, 2023 at 5:52 PM Post #8,621 of 9,551
Better than I expected, just asolid good budget cable. Look good also with fake Furutech hardware.
Thank you very much for the recommendation, I will check the cable.
Kbear akkord
Tripowin zselé
HAKUGEI Rizs litz
NiceHCK JIALAI (szövött)
Köszönöm szépen az ajánlást, megnézem a kábeleket.
For which IEM?
AKG N5005 is the iem. Overall, I am not satisfied with the sound of the cable, especially the high frequency is very sharp. This was my problem with the K3003i cable. I want a more neutral, balanced cable. Thanks for the help!
Kbear akkord
Tripowin zselé
HAKUGEI Rizs litz
Sep 7, 2023 at 9:53 PM Post #8,622 of 9,551
Hakugei Big Rice
NiceHCK MeetAlice
Both reduce high mids/treble influence.
Big Rice gives more bass, but not so much clear and transparency sound.
MeetAlice gives much better and balanced frequency response, with better resolution and clarity.
Sep 8, 2023 at 9:59 AM Post #8,623 of 9,551
^ I too have a number of XINHS cables and that is the one that I like the most.
It’s a surprisingly resolving cable that enhances midrange while keeping treble and bass extended without dominating the mix. It doesn’t actually make the sound thick though. In fact it’s very clear and transparent in how it handles transients.
It also has a blacker background than anything else I’ve tried in its price range.
+1 recommendation for that cable.
Great to pair with a warm IEM, everything is very clear and well separated👌🏻
Finally something more lightweight again.
While I love XINHS 4 core Silver plated single christal copper it was just too heavy for daily use that's why I got this one and I am absolutely satisfied (got it for 68€)
First I was not sure about the resin and asked to customize it but they talked me into it and now it turns out I love the looks 😁
Sep 8, 2023 at 5:09 PM Post #8,624 of 9,551
+1 recommendation. I received mine today and gave it a try with my FiR VxV (which I consider a warm iem). Sounds fantastic. Compared to stock increased detail and still punchy, deep bass. I also believe it beats my PW Audio No10 (SPC) on this iem.
Sep 8, 2023 at 9:45 PM Post #8,625 of 9,551
XINHS have two stores on AliExpress. The prices listed are the regular prices although they do offer better discounts on some items during sales. They will produce custom cables if requested. Right angle plugs, different cable lengths or leaving earhooks off for example. :L3000:
