Low end. Cheap. Generic. Otherwise bang for buck cable thread!
May 18, 2023 at 8:48 AM Post #8,446 of 9,223
NiceHCK OrangeSir is a good copper cable. Alternatively PurpleSE or BlackCat. NiceHCK C16-3 is also good but not quite as robust being 16 cores (very comfortable though). They have all just come off sale for under $15. The regular prices are much higher (it in fact stretches credibility the anyone buys them outside of sales). They should be back on sale at the end of June for the Summer sale on AliExpress. Alternatively look for OCC/monocrystalline copper at XINHS or I V Music stores. They are OEM suppliers and are often much cheaper than boutique brands.:L3000:
If I may ask is there is a difference between a Copper cable covered with PVC vs Fabric?
Sadly, Aliexpress does not ship to my country. I have someone visiting UK, so I can ship it to the person and get them when the person is returning. Thus, sale window I would sadly miss.
Also, Thank you for those suggestions, I would definitely check them out. You are correct, about the cost when it is a boutique brands. The thing is, I am unaware of the right brands/models, as when I go for Nice or XINHS they have so so so so so many models, it gets confusing :grin:
May 18, 2023 at 9:14 AM Post #8,447 of 9,223
I know exactly what you mean. My suggestion would be to try a Xinhis (sic) cable from ConceptKart (Indian site), they have the 4 core copper as well as the 8 core silver plated cables. Do check them out.
Edit: I could never get the spelling right XINHS
May 18, 2023 at 9:28 AM Post #8,448 of 9,223
Great advice here. I’ll add that the BlackCat has a small boost to mids, which can be good or bad depending on your needs. PurpleSE is probably my favourite sounding budget cable, out of far too many. Like Carpet said, only buy NiceHCK cables in sales. All three he suggested should be under $20 each.
May 18, 2023 at 10:07 AM Post #8,449 of 9,223
Hi, I want to find a budget MMCX cable for my brother (~$50) that pushes a little in highs and soundstage, any recommendations? Thanks!
May 18, 2023 at 10:40 AM Post #8,450 of 9,223
Sounds like you might want to get a pure silver cable. Xinhs are trustworthy and do one in your price range.
It does depend what he is currently using - if it’s a bad cable, it may be reducing treble. In that case he may just need a simple nice quality copper or silver plated copper.
May 18, 2023 at 10:44 AM Post #8,451 of 9,223
Anyone tried it before? I just ordered one for the beautiful ends. It looks cool. Model name ivipq - 101. It has a price of 45 euros, it seems very affordable for the tips.
May 18, 2023 at 7:07 PM Post #8,452 of 9,223
Xi - President of China
NHS - British health system
Maybe not super obvious, but it works for me! :thinking:
May 18, 2023 at 7:17 PM Post #8,453 of 9,223
haha this definition is so cool.
May 18, 2023 at 8:46 PM Post #8,455 of 9,223
I always remember them as SHNIX having seen the writing on one of their cases upside down
May 19, 2023 at 3:33 AM Post #8,456 of 9,223
Some of my pure copper cables.
Different terminations for different IEMs and headphones. 2-pin, MMCX, 2x3.5mm so can't really compare soundwise. If I can even hear any :thinking:
XINHS 4 Core 6N Single Crystal Copper is AFAIK the most expensive pure copper cable from XINHS. It was mentioned as bright here with Final B3+Hugo 2
https://www.head-fi.org/threads/low...ck-cable-thread.891911/page-520#post-17133677 I don't perceive the XINHS as bright on Focal Clears.
The XINHS and Hakugei Rice are the most premium feeling.
Lunashops 16 core has the softest handling. Makes sense for a 16 core vs 4 and 8.
NiceHCK GCT5 feels like the thickest one, but I believe due to insulation being thicker than XINHS. Not more copper.
Hakugei Rice was thinner than I expected.
The 8 core NiceHCK PurpleSE and Orangesir handles similarly. Orangesir seems slightly thicker.
Stickiest rubber coating: 1. XINHS, 2. GCT5 and Hakugei. 3. PurpleSE and OrangeSir 4. Lunashops.
The hardware on Hakugei is smaller than the others, preferable if you want a light and less clumsy cable.
They are all nice cables.
77 x 4 = 288 total
Measured resistance using Uni-T UT161D: XINHS 4 Core 6N, 0,2Ω on all (6,35mm to 2x3,5mm termination)
https://www.aliexpress.com/item/1005003292429971.html?
Ali part no 1005003292429971
Hakugei Rice Type4 Litz 6N OCC 4 Core
133 x 4 = 532 total
Measured resistance using Uni-T UT161D: Hakugei Rice, right channel: 0,1Ω 0,2Ω left channel: 0,1Ω 0,1Ω (3,5mm to 2-pin 0,78 termination)
https://www.aliexpress.com/item/1005003765546551.html
Ali part no 1005003765546551
NiceHCK GCT5 5N OCC 4 Core
0.08mm*60 each strand = 240 total
Measured resistance using Uni-T UT161D: GCT5, right channel: 0,1Ω 0,1Ω left channel: 0,1Ω 0,2Ω (4,4mm to 2-pin 0,78 termination)
Search URL https://www.aliexpress.com/af/gct5.html?
https://www.aliexpress.com/item/1005005048275456.html?
Ali part no 1005005048275456
Lunashops 16 Core 99% 7N OCC (LN006998)
hundreds of configurations on Aliexpress from 3 the Lunashops stores.
NiceHCK OrangeSIR 8 Core
6N OCC + high conductivity copper mixed
Measured resistance using Uni-T UT161D: OrangeSIR, 0,1Ω on all (4,4mm to MMCX termination)
Search URL https://www.aliexpress.com/w/wholesale-NiceHCK-OrangeSir.html
https://www.aliexpress.com/item/1005005048292247.html?
Ali part no 1005005048292247
NiceHCK PurplesSE 8 Core Furukawa Copper
Measured resistance using Uni-T UT161D: PurpleSE, right channel: 0,1Ω 0,1Ω left channel: 0,1-0,2Ω 0,1-0,2Ω (4,4mm to 2-pin 0,78 termination)
Search URL https://www.aliexpress.com/w/wholesale-NiceHCK-PurplesSE-.html?
https://www.aliexpress.com/item/1005004383629709.html?
Ali part no 1005004383629709
Top to bottom
  1. XINHS 4 Core 6N Single Crystal Copper
  2. Hakugei Rice Type4 Litz 6N OCC
  3. NiceHCK GCT5 5N OCC 4 core
  4. Lunashops 16 Core 99% 7N OCC
  5. NiceHCK OrangeSIR 8 Core
  6. NiceHCK PurplesSE 8 strands Furukawa Copper
Top left to right
  1. NiceHCK PurplesSE 8 strands Furukawa Copper
  2. NiceHCK OrangeSIR 8 Core
  3. Lunashops 16 Core 99% 7N OCC
  4. NiceHCK GCT5 5N OCC 4 core
  5. XINHS 4 Core 6N Single Crystal Copper
  6. Hakugei Rice Type4 Litz 6N OCC
May 20, 2023 at 1:53 PM Post #8,457 of 9,223
Hello All,
I am looking for a good cable for IEM (2 pin). From my understanding, Copper gives a warmer sound, Silver or silver plated ones are lil more airy. I prefer the former.
My budget is maximum 100$, and I just wish for it to be a good, durable, cable. I was looking at Hakugei Healer, Moondrop Autumn Moon, Hakugei Silver Surver, NICEHCK C16-3, KBEAR Enma 8 Core, ivipQ-93 etc. Is there any particular you might suggest that would fit my requirement.
https://m.aliexpress.com/i/1005005327312217.html
Best priced cable for your requirement. Best value for money and amazing detailed, all-rounded sound, massive Soundstage.
Pm me if interested.
May 20, 2023 at 2:54 PM Post #8,458 of 9,223
There are serious discounts on ivipq. They have slightly different working styles, you can negotiate. They also do customizations to the cables, I ordered one and am waiting. I have nicehck purplese and silverse and ynuoo, waiting for ibipq. If they are as good as they look, I can shift my cable orders to ivipq.
May 20, 2023 at 6:15 PM Post #8,459 of 9,223
If i want to do it myself .. is there a recommended seller on AliExpress that can supply good wires for cables .. there is a seller called : hakugei that seems to have wide variety of diy iem cables that i liked some already .. if any confirmations or other suggestions..would be much appreciated 👍🏼
May 21, 2023 at 5:58 AM Post #8,460 of 9,223
XINHS Headphone Cable HIFI Store sells those, otherwise either of the XINHS stores will customize cables too. :L3000:
