Johnfg465vd
Hmm, if you are up to it you can cut off the plastic sleeve with a blade.I don't want anything with memory wire or a plastic sleeve
Got it. I don't remember seeing such a cable but will share here if I find something.I'd be nervous after what happened to my effect audio cables
Satin Audio doesn't have shrink wrap earhooks. They start at about $100 for 4 wire version of their entry level cables and go up from their. I have an 8 wire version of their Chimera II which was about $200. It's not thin but it's not a particularly heavy cable either. The 4 wire version wouldn't be the thinnest cable but again, no ear hooks and wouldn't be considered a heavy cable. Or, the DDHiFi Forest cable comes to mind. It's an OCC copper cable, thin, light and no earhooks. Come in MMCX or 2-Pin, 2.5mm ... about $60. It's much thinner and lighter than it looks in photos too.
If you want to go cheap, buy something like a TRN or FDBro (or any number of different brand names) 8 core cable and cut off the shrink. You can use one of those thread/seam rippers that are used for sewing or a small pair of wire snips. I know you said that you destroyed an Effect Audio cable by trying but it's easy to remove the heat shrink and you'd only be out about $20 if you managed to screw up one of those cables.
DDHiFi Forest ... https://www.aliexpress.com/item/1005002466022526.html?spm=a2g0o.detail.1000060.1.7e7453c47gHFuj&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=0de9126d-75a4-4a48-8c3f-00b1da86b4c1&_t=gps-idcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:0de9126d-75a4-4a48-8c3f-00b1da86b4c1,tpp_buckets:668#2846#8115#2000&&pdp_ext_f={"sceneId":"3339","sku_id":"12000020754728671"}
ALO Audio cables are pretty thin. At least the less expensive ALO cables are. And I believe they are the cable maker for Campfire Audio, or at least for some of their iem models.
ALO Pure Silver Litz has no memory wire or shrink ... if you want silver and want to spend $200.
By far the softest cable I have ever used. It's like a soft rope.
I've tried every one of them and while the lower models are soft the 24 core's PVC coating is the softest. Also, the 24 core can handle more power too. On my desktop setup the lower models clip on my a30 pro amp anything past 12 o'clock on medium gain.Might have to check out a lower core model, they have a pure silver model too. I wonder if that's soft.
The 24 core however can go past 12 o'clock on high gain without clipping. It's deafening but no clipping. If your not using over 3W of power this is no concern but something to think about.
