brsdrgn
Ordered the following cables from NiceHCK's Store. I'm especially excited about the Blue Island.
I did consider something like the BlueIsland from XinHS offerings, but I asked them for the weight of the cable and they said 50 grams. That's pretty heavy 0.oOrdered the following cables from NiceHCK's Store. I'm especially excited about the Blue Island.
It's okay if it's heavy. I really like its designI did consider something like the BlueIsland from XinHS offerings, but I asked them for the weight of the cable and they said 50 grams. That's pretty heavy 0.o
Sadly, my cable already has problems. The fabric outer layer has a tiny segment of the inner wire bulging out in two places. One is bigger and is basically a loop with fabric on one side and the plastic covered wire on the other. I've contacted Nice HCK to see what they have to say. This is both the shortest amount of time I've owned a cable before it developed a problem and the most disappointed I've ever been with a cable because I loved it for the four or five days I've had it.
About 3-4 weeks.For those in the US and have ordered from XINHS, how long has it taken for you to receive your cables?
A1 is stiffer than the A3, one factor for that is because it is 8 vs 4 cores.Is A1/A16/A31 softer than A3? @RikudouGoku @paulwasabii
Darn, that sucks bc my only complaint with the A3 is that I wish it were a bit softer. It's not super stiff though and feels like it's very durable. Maybe I'll try a 16 core, the Tripowin16 core I've tried was really soft.A1 is stiffer than the A3, one factor for that is because it is 8 vs 4 cores.
A3 is already one of the softer cables in my collection. So yeah, you might want to go for a higher core count to be softer.Darn, that sucks bc my only complaint with the A3 is that I wish it were a bit softer. It's not super stiff though and feels like it's very durable. Maybe I'll try a 16 core, the Tripowin16 core I've tried was really soft.
https://docs.google.com/spreadsheet...zTm4ei7HEfP8AI1zxswrMw2ho/edit#gid=1801072063So, can someone recommend me a balanced 2.5mm cable below $25usd ? Or even better, a couple of those for $30.
Lots of the cables that are recommended in the firsts pages doesn't exist anymore.
I haven't measured but I've used it. It is the first balanced cable that I bought as I am curious if shifting from single ended to balanced makes huge sonic difference. All in all, it sounds pretty bad compared to any 30 ~ 40$ cables that could be purchased from Aliexpress. If you want something that could allow you to listen to the music, it is fine but you believe that cable could give you different or better sound, it is no go.Anyone here ever measure the Tripowin Zonie? Probably the most popular IEM cable on Amazon US.
Thanks for the list!https://docs.google.com/spreadsheet...zTm4ei7HEfP8AI1zxswrMw2ho/edit#gid=1801072063
Pick one of the A series based on aesthetics.
