Low end. Cheap. Generic. Otherwise bang for buck cable thread!
- Thread starter Dsnuts
- Tags
- aliexpress cable
How's the bodhi?This is Hakugei Bodhi, came from Shopee.
As anyone tried this cable? I like the aesthetics, the fact that is lighter than the 8 core version and that it includes graphene, Cooper and silver.
https://pt.aliexpress.com/item/1005...exp_id=7a71b832-1bba-4acc-8a70-1d0b5f450e67-5
The price is ok also!
I have both 4 core and 8 core versions of it and 8 core one shows better characteristic of the cable materials. I would rather choose 8 core one if the thickness (actually not that thick) doens't bother you.As anyone tried this cable? I like the aesthetics, the fact that is lighter than the 8 core version and that it includes graphene, Cooper and silver.
Thanks for your feedback. Is you 4 core version with or without copper?I have both 4 core and 8 core versions of it and 8 core one shows better characteristic of the cable materials. I would rather choose 8 core one if the thickness (actually not that thick) doens't bother you.
For the price, what would be the best option for the ISN h40?
Construction of cable is refine for US$60.How's the bodhi?
How's this cable (need for iBasso IT01)? https://www.amazon.com/Linsoul-Tripowin-Silver-Earphone-0-78-3-5mm/dp/B07ZQC9MZB/ref=sr_1_3?dchild=1&keywords=iem+cable&qid=1624615833&sr=8-3&th=1If you have trained ears, it might.
Never own it, but i see its Amazon's Choice, saferHow's this cable (need for iBasso IT01)? https://www.amazon.com/Linsoul-Tripowin-Silver-Earphone-0-78-3-5mm/dp/B07ZQC9MZB/ref=sr_1_3?dchild=1&keywords=iem+cable&qid=1624615833&sr=8-3&th=1
This is one of the very first aftermarket cables I purchased.How's this cable (need for iBasso IT01)? https://www.amazon.com/Linsoul-Tripowin-Silver-Earphone-0-78-3-5mm/dp/B07ZQC9MZB/ref=sr_1_3?dchild=1&keywords=iem+cable&qid=1624615833&sr=8-3&th=1
The cable is very light and soft but the cores are very thin.
So it's good? xDThis is one of the very first aftermarket cables I purchased.
I think there are alot better options for the price.So it's good? xD
RikudouGoku
Member of the Trade: RikuBuds
YesLess then a day left before sales ends?
CommanderCute
Hey guys,
I'm looking for a replacement cable for the FD5. Love the looks of the cable (white with silver), but it's just too stiff and inflexible for my taste.
Which inexpensive cable (with the same looks and that it should be very soft and flexible) can you recommend?
Thanks
Thanks
Total: 17 (members: 0, guests: 17)
