Module
- Jul 11, 2015
https://www.aliexpress.com/item/32965995788.html Is this silver-plated copper or pure copper cable? Seems interesting, litz cable for cheap (~$50).
Seems like a hybrid cable, between copper and silver.https://www.aliexpress.com/item/32965995788.html Is this silver-plated copper or pure copper cable? Seems interesting, litz cable for cheap (~$50).
i use any of the IEM (MMCX / 2pins 0.78) cables of my list with Ananda and HE400i. just use the MMCX/2pin to 2.5/3.5mm ultra short quality adapters.Hi all. I'm choosing cable for my Hifiman Ananda. Will order from aliexpress. Can someone tell me if Lunashops cables any good? For example: https://aliexpress.com/item/4000711160302.html or https://aliexpress.com/item/33055252206.html ?
It's sad hakuzen measured mostly cables for IEMs, I found only GUcraftsman cable in the list have 2x3.5mm option.
Ah yes, budget $50-150.
got mines at taobao, various shops.This adapters look great. Would you have a link for a shop online ?
I'm looking for a high quality 3.5mm cable with microphone (and volume controls preferably). Getting sick off taking off my IEM's to take work calls!
Both QDC and MMCX options welcome
select the components at CEMA electro acousti shop at aliexpress, and ask them for a quote for the ready made cable. tried that extension cable time ago, but i needed around 3m long, and the work of braiding 8 cores so long was excessive. but for 30-50cm long, they won't have any problemWould someone please recommend a 2.5mm female to 2.5mm male balanced audio extension cable (~30 to 50 cm long)... for the life of me I am unable to find anything under 150cm!
I have seen some skilled hands dab a very (and I mean very) small amount of super glue in between the cables at a few key strategic locations keeping them locked together... preventing them from unraveling/untwisting.Some of my cables (173 and 196, both 4 cores) are starting to untangle themselves. Any way to fix it?
I buy all my cables in 2.5mm balanced and if I have a source with only 3.5 out like my IFI Black label amp. I use a female 2.5mm adapter that ends with a 3.5mm single end AKA pigtail adapter. Most of my sources has 2.5mm out so this is the most logical method of buying cables for me. Balanced cables are only usable on balanced sources. But have the added benefit of becoming single ended using an adapter. You can't go the opposite way however.
