superuser1
How about something like this
I've certainly considered it, but would rather a simple, 'low profile' 90* jack.How about something like this
Whith you on that mate. Since I got 64a mic cable, that is saving my ears from removing/inserting my customs all the time.I'm looking for a high quality 3.5mm cable with microphone (and volume controls preferably). Getting sick off taking off my IEM's to take work calls!
Both QDC and MMCX options welcome
that's right, unfortunately it is for 64a range that are 2pin. Not on the "low cost range", but Plussound used to have good ones and they can be built with any connector.Nice, I had a look at that cable, looks like it's 2-pin and doesn't come in QDC or MMCX options?
Have a try on their thread. Paul is really attentions and will respond to your direct message really quick too. He gave me a few tips on cable matching to my IEMs before, based on my preferences and everything and he is really open to unique orders.Cool. Looks like they're website is down https://www.plussoundaudio.com/customcables/inearmonitor.html
I think both are the same cableWhat are the difference between these 2 cables?
https://www.aliexpress.com/item/4000297658368.html
https://www.aliexpress.com/item/4000400771561.html
They both looks like the Faaeal Litz cable but one is more expensive and the other is out of stock (other than 3,5mm).
I might be wrong here, but I believe you can ask Electro acousti to make a custom cable for you.Hi all. I'm choosing cable for my Hifiman Ananda. Will order from aliexpress. Can someone tell me if Lunashops cables any good? For example: https://aliexpress.com/item/4000711160302.html or https://aliexpress.com/item/33055252206.html ?
It's sad hakuzen measured mostly cables for IEMs, I found only GUcraftsman cable in the list have 2x3.5mm option.
Ah yes, budget $50-150.
You can ask electro make dual 3.5 just tell them hifiman wire configuration.Hi all. I'm choosing cable for my Hifiman Ananda. Will order from aliexpress. Can someone tell me if Lunashops cables any good? For example: https://aliexpress.com/item/4000711160302.html or https://aliexpress.com/item/33055252206.html ?
looks very much like the ibasso it01s cable. It is thick and not very flexible. Sounds good but I don't like the ergonomics...Does anyone have experience with the following cable?
https://a.aliexpress.com/_BTBPQO
I was told that it has amazing haptics, though the conductivity supposedly suffers due to the unique configuration.
