Does this device have optical out to feed FLAC files to another external DAC?Hello
I'm looking for the lastest firmware for the PAW 5000 MK1.
My version is 6.0.1.7 and I installed from a firmware file called "PAW 5000 Firmware6.1.0.7_EN"
Now there is a version 6.0.1.14 on the website called "PAW5000_AP_6.1.0.14".
See link
Does anybody know, wether this file has also the english menu or only chinese?
Does anybody already installed it?
Don't want to upgrade to an all chinese player
Regards
Steffen
Lotoo PAW 5000: Impressions Thread
- Thread starter pekingduck
Hugs and Kisses
Has a Line Out/SPDIF.
Blazer39
- Apr 30, 2015
anyone knows how to open lotoo 5k mkii?
i have problem with the jog wheel, its not responding well and navigation in it kinda of a chore now.
i assume its hardware issue, was hoping maybe can fix it by hand
Im thinking of getting the mk2 but are the firmware/software bugs fixed? I read about a few dealbreaking bugs like it hangs and needs to be resetted etc but that was many fw versions ago.
My guess is that there will be no mk3 since the reveal of the Paw 6k. $1000 is still tio much for me...
Didn't notice any bug on my P5000 mk2, and I've had it for quite a while. Can you redirect me to what you read ?
I've been looking and looking but i cant find it. Some guy had huge problems and had to carry a reset-pin since hes player hung quite often. I'ts either in this thread or the obscure chinise daps-thread.
But if you have no problems, i guess its sorted or he had a bad unit.
Can i ask how they player holds up today? Does it read metadata from files yet? Like album, artist etc.
Im torn between the paw 5k mk2 and the ibasso dx120. Totally different players but the dx120 has so much more modern features like reading metadata for example.
Richsvt
Mine also had never hung, just works all the time. It's a funky UI but once you get adjusted to it, plays like a dream. Serious EQ control if you're into that. Powerful player. Nice footprint, not too small but great for carrying around.
Hugs and Kisses
How the time flies, I remember posting here when I first got the MK II. It has been almost two years and my player has been used daily. As for hangs and issues, I have not had any from day one. Every penny I spent on this player has been worth it. One needs to get used to the menu format/navigation. One day I may change the internal battery.
Firmware version 7.1.0.19 has been a round a while now. Link is below.
http://www.lotoo.cn/english/bottom/Service/Download/Hi_Fi_Music_Player/2020/0428/82.html
yag-freak
- Oct 4, 2005
Thanks for the link!
I picked up a 5000mkii from a fellow head fier and it arrived today. I'm excited, but I'm having difficulty getting windows 10 to recognize the device. Anyone have this problem and could share some advice? It did not come with a cable but I have a spare usb to micro b. When I connect it will charge, but windows doesn't register that a drive has connected, although the device does give me the usb connection countdown...
Thanks!
Thanks!
- Can you first confirm the cable is a data cable and not just a charge cable? If you have another device that you are 100% certain presents itself as a mass storage device that uses micro USB, try this cable on that.
- Assuming the cable is a data cable, the Lotoo might not be presenting itself as a mass storage device. Check Disk Management to see if Windows detects it as a drive at all — it may be that the file system is just unrecognized by Windows and requires reformatting the drive or possibly even repartitioning it from within Disk Management.
Sorted it, a very very simple solution. The scroll wheel had to be switched from usb power to connection. Based on how it looked it didn't seem like there was an option; it just seemed to be saying the connection was to 'usb power'
gregorya
- Mar 5, 2011
Yes, that is not the most intuitive method for configuring the connection... enjoy your new purchase!
I had the opportunity to transfer some music and give a listen. My previous dap was a Ibasso DX220 with Amp9, which I didn't feel justified keeping because it just wasnt getting enough time. I picked up the 5000mkii used at 1/3 the price which felt more reasonable for the amount of portable use I get.
What a steal. Not missing the ibasso at all. With the blessing 2 dusk this is a great little player. I'm going to have to try this out with my er2xr (only other pair of iems) to see if it's just as magical.
Total: 6 (members: 0, guests: 6)
