Lotoo PAW 5000: Impressions Thread
Discussion in 'Portable Source Gear' started by pekingduck, May 6, 2015.
48 49 50 51 52 53 54 55 56 57
59
  1. yag-freak
    Hello
    I'm looking for the lastest firmware for the PAW 5000 MK1.
    My version is 6.0.1.7 and I installed from a firmware file called "PAW 5000 Firmware6.1.0.7_EN"
    Now there is a version 6.0.1.14 on the website called "PAW5000_AP_6.1.0.14".
    See link
    Does anybody know, wether this file has also the english menu or only chinese?
    Does anybody already installed it?
    Don't want to upgrade to an all chinese player :)
    Regards
    Steffen
  2. JayceOoi
    Using it now. It has both English and Chinese as always. No worry... :)
    HungryPanda likes this.
  3. the diode
  4. yag-freak
    Hello JayceOoi
    Thank you for the Info.
    As I said the last update to .7 was in a time where there were explicit EN Firmware versions.
    So the .14 is the first for me from the "multi language" versions.
    Just updated it 15 min ago and it works like a charm.
    I still like this little player and now that i had it in hand, I will use it more often in the next time.
    It's like with many things. Sometimes the highest end is not the most used gear in your possesion, because it is too cumbersome to lug arround.
    The best music is the music that's with you in your life.
    Regards Steffen
    JayceOoi likes this.
  5. NehPets
    Could any of the PAW 5000 MK II owners out there tell me whether the line level output is FIXED or ADJUSTABLE? Thanks.
  6. HungryPanda
    It is fixed
  7. jonsim86
    Just a quick question. Read thru most of the thread regarding mkii.
    Any comparison between LP5K and LP5KMKii?
  8. Blazer39
    i should be getting mkii perhaps around next week and already have the original one...however im absolutely certain that mkii is waay better than the original, as it actually has legit DAC and AMP section..which the first one lacked and just used chip.
    also it seems mkii is in the same league as opus#1 if not better( in terms of SQ of course)
  9. Sound Eq
  10. Youghin
    same here, waiting for it...
  11. grownmansport
    Considering getting the mkii and have a question on folder navigation. If I have album folders under each artist folder, can I shuffle all tracks by an artist, or is it only possible to shuffle play within one album?
  12. geagle
    You can, but there's a "trick" : you go to the folder you're interested in (artist, in this case), you add the whole folder to a list "on the fly" (that also adds the subfolders), and then you play the list
    trellus and grownmansport like this.
  13. grownmansport
    Thank you so much! Very helpful to know this before making a decision.
  14. z0del
    Hello. Any words about LP5K in nowadays with latest firmware? Would it be a good buy or not? Thanks.
    dudiadudia1 likes this.
  15. thesheik137
    Review that convinced me to finally buy one.
    Torment, HungryPanda and trellus like this.
59
