Just to be clear in case of misunderstanding, my LD has RCA 6AS7G power tubes whereas my APPJ, the speaker version, has EL84's
Oh, ok. Why is this? The schematic you linked has 6P6 which is soviet 6V6GT.
I can tell a Tungsol from a Sylvania regardless of whether it is a 12AX7 or a 6SN7, therefore tubes by the same manufacturer but completely different construction.
Both in a circuit with a resistive anode load of less than 10x rp --> very small rp differences will be altering the function of the circuit.
Theory time:
Everybody understands how a voltage divider works, right? You have two resistors between + and ground, and the junction node voltage is determined by the resistors.
Now imagine you make the bottom resistor a potentiometer. You wire it as an adjustable resistor. You take your hand and you turn the wiper; the junction node (which is above the pot of course) voltage then varies, because the top resistor stays the same.
Are you following so far? Simplest ohm's law stuff, nothing to worry about.
Now if you make the + voltage really big, let's say 300 volts, and the top R 100k, and the pot max value is 100k. You now have a certain adjustment area.
Let's say your hand moves in tandem with a sine wave you see somewhere. Now as you move the pot wiper, you are in fact controlling the R / pot junction node voltage.
Let's say you move the pot all the way from open to max value during the sine cycle. You get junction voltages between 0V and 150V.
Now if you keep the R same value, and change the pot to a 90k max value pot, you get junction voltages from 0V to 142.105 V. Same input, your hand moves the same amount, but different output.
A tube is actually just an adjustable impedance. The above example can be expanded and clarified to apply more to an actual tube, but it would become much more complicated when you take into account resistance vs. impedance etc. It's a good enough analogy as it is.
So the principle is that if you have anode R that is not very big in comparison to rp, then if rp varies (it varies during operation, I mean statically between different tubes) it will cause the circuit to operate differently.
If anode R (or rather, Z) is large enough to drown out the influence of rp (remember, they are always in series between + and ground, one of them is by necessity dominant in determining the current thru that node and the junction node voltage), then variations in static rp (between different tubes) is meaningless.
What you are hearing is that some manufacturers are "over spec" in some specs, and some are "under spec". Whether or not these are consistent across different tube types within a manufacturer seems a bit odd, but not completely out of possibility.
Anode resistance is key here. A reason why some tubes sound "dark" and some "bright" is because a small variation in rp changes the R in an RC lowpass or highpass filter somewhere in the circuit. Why somebody would want to make a circuit that is so vulnerable to small variations is beyond me. I try to eliminate them.
The tube itself isn't "dark", you just dropped in a component that had "the wrong value". Let's say you'd have an RC highpass filter. You have a C of 100nF. Now you solder in as the R a random resistor. You cannot see it's value. What frequency pole ("sound") will you get? This is tube rolling in an essence.
