I plan to ugrade PSU caps to MUNDOLF brand
4 x coupling with K75-10
8xMills MRA5 150R/5W resistors
A lot of cables I have own so cable upgrade is skip
After some times self learn and pratice, soldering isn't any issue anymore.
Since last mod experience, take off the whole board out from the amp is not hard at all
Myself already own some drivers tubes & NOS, so skip tube row
Everything you do with this design will make a difference(!)...
but the PSU improvements are the lesser,
compared to the most important noticeable upgrades,
which are:
1- the coupling caps
2-the WCF caps
3- and the bias adjustment to the driver tubes...
those are three areas of concern that I would do first,
because they will give you your most noticeable improvements currently....
The psu stage upgrade is also an improvement...
But the other mods we do to the rail voltage stated in first page also does same.
Although it is true that the PSU in every amp will interact with its load, the design of the PSU for the powerubes in this amp has already been stated as "musical" as is from a designer..
And yes it is a simplistic but beefy PSU.
