Hi guys!
I had some time today so I took some measurements of the MK6. Thought I'd post them here for you guys to see!
Amp in question:
I started by measuring all important voltages of course (I haven't used this amp in quite some time). All voltages were good!
As some of you know I've built
@MrCurwen LTP design which is a forced balanced design by the CCS (constant current source) tail. If I inject a signal in one phase of one channel in the LTP and
ground the other phase, both phases output the exact same amplitude!
So, I thought it'd be fun to do just that with the mk6. I had to leave one phase input floating or disconnected for this to work. Could barely get a reading with one phase grounded.
Input signal is 700 mVpp @ 1kHz
A 100 ohm resistor as load across the right channel outputs. Scope and DMM probes hooked up across it.
This is what came out at full volume. 2.28 Vpp from a 700 mVpp input signal gives me a total gain of 3.26. Remember, the ECC35 has µ68 and 6AS7G has µ2, so full gain would be 136. That's the NFB.
Oh yes, I have the gain set to low, so maximum amount of NFB!
Here's the measurement from the phase without input signal (same channel). I just flipped the scope leads on the load R.
As you can see there's barely any signal there at all.
Also thought it'd be fun to do a power output measurement. Remember, gain still set to LOW!
This is right before the sine wave starts to round off at the bottom.
7.1 Vrms ^2 / 100R (load) =
0.5 Wrms or.....
10 Vp ^2 / 100R (load) =
1 Wpeak
I don't know how much the low gain setting affected power output but for fun I also simmed the MK6 in spice:
Also with low gain setting. If I drove it any harder than this the signal would clip. This is about 15 Vpp with 100 ohm load. I don't know how accurate spice is when doing these types of measurements but use it as entertainment at least.
Both phases have input signal here as you can see. Nice and balanced outputs. The voltages at V4 and V5 are adjusted to get 0 VDC at output. Don't know how accurate those are either.
Edit: I got curious and measured the voltage at the top triodes grids. It was in fact very accurate at -23 V!
I did not post this to bash on the MK6 in any way. I still think it's a great sounding amp!
