Little Dot MK8SE / MK6 Super Mods (All verified mods are on first page)
Jan 20, 2018 at 9:09 AM Post #2,716 of 4,154
The goal here was to get as much B+ as possible, give the tubes as low current as possible without any SQ drawback. We work with what we have here, though 250+ V B+ would of been much better, of course.
Just make a voltage doubler. Only requires a few parts.
APPJ's is speed and sharp transient leading edges which the LD does not quite have,
Film caps in the mk6 power supply solves this.
Oh you mean the CCS mod, I don't know if that's part of a LTP on the LD, waiting to hear more!
it is.
Jan 20, 2018 at 9:41 AM Post #2,717 of 4,154
Jan 20, 2018 at 9:54 AM Post #2,718 of 4,154
I don't exactly recall what was in the PSU, but I'm sure it could just be tossed and put a simple RCRC with small R (like 100 or 200 R) and a simple 2 FET reg. Then you'd have more or less about the same B+ voltage, which is fine.
Use cheapest resistors and 105 degree 47µF electrolytes. Absolutely no difference in sound quality either theoretically or observably is going to be happening. It's a constant current draw stage at that point and behind a regulator. Put one 1 to 4 µF film cap after the reg for stability. Russian MBGO 4µF recommended. No observable sound quality difference either way, this cap is for stability and nothing else.
Then just put the gyrators in there. The input stage only needs to provide a small voltage output because of the nature of the amp as a whole. No need for 70V voltage headroom, 10 or 20 will suffice, 50 will be overkill.
With gNFB and adding stuff inside the loop stability is always a concern. But I guess there's only one way to find out; stability cannot be simmed.
Jan 20, 2018 at 10:00 AM Post #2,719 of 4,154
After the mods described in my previous post having the input stage inside the loop is actually only hurting the sound quality of the input stage. It is however still required for making the output stage have a useable output impedance.
Jan 20, 2018 at 10:04 AM Post #2,720 of 4,154
Edit: Oh you mean the CCS mod
No, I mean this: https://www.head-fi.org/threads/modern-balanced-tube-amp-build.852879/
But, yes. I also recommend the CCS mod for the MK6!
I guess this is one of those which simmed better in spice than it performed in real life.
If I inject a signal in one phase and say the output is 2 Vpp. Then the output of the phase without input signal is about half, so 1 Vpp. Still much better than before but not "forced balanced". But when listening to music we have input signal in both phases, of course.
All in all I think it sounds much better than before! As it should.
Jan 20, 2018 at 10:08 AM Post #2,721 of 4,154
Thanks, we will look into this. As I said it is not a problem for me because I like a non fatiguing sound over headphones, nevertheless to get the most definition it may need to be done.
Jan 20, 2018 at 10:08 AM Post #2,722 of 4,154
Have you looked at any of the pics I've posted? There's absolutely no room for any reg's or gyrators and most definitely not any russsian caps, lol! Sure, I could rebuild the psu filter, but without the reg there's no point.
Jan 20, 2018 at 10:55 AM Post #2,723 of 4,154
You wasted all the space using an elaborate ccs scheme instead of a 2 terminal scheme. I also said there are low profile gyrator pcbs you can buy. You seem to be ignoring me so I'll just leave it at that.
Jan 20, 2018 at 11:38 AM Post #2,724 of 4,154
Well, I had all parts on hand so...And I trust MrCurwen's advice as it has worked out great for me so far.
Do you have any pics with these boards fitted inside the MK6?
My goal is not to mimic the modern LTP. I already built my dream amplifier so there's no point in trying to make the mk6 sound just like it (I realize it never will with the WCF output stage). If other people are willing to extend the bottom of the chassis or make a separate box for the input stage, that's totally understandable. After all that was my initial goal before I built the modern LTP.
Jan 20, 2018 at 12:33 PM Post #2,725 of 4,154
It's an upgrade to be sure, I still don't trust the b- connection though. Any harmonics that get through the current source will be heavily amplified. Like I said you might want to scope your b- supply to see how dirty it is. The dirtier it is the less impedance the current source will provide and the more unwanted harmonics will leak into the input stage.
I only applied my improved wcf mod to my mk6 a while back. My headphones bit the dust after years of abusing them in experiments so I didn't see the point in doing any more mods. I'll soon be repairing them while I build full scale prototypes of one of the amps I designed.
That being said the PCBs are mostly flat, the mosfet is the exception but it can be bent back. http://www.bartola.co.uk/valves/for-sale/gyrator-pcb/ I would be surprised if you couldn't squeeze it in there.
The WCF may not be technically optimal but it does a lot of things well in OTL and has the hidden advantage of how it sounds when mixing tubes. There are ways to make the wcf and the "modern LTP" perform much better without the need for feedback, I'll soon find out how this better performance translates into sound in the next few weeks.
Jan 20, 2018 at 12:49 PM Post #2,726 of 4,154
I have looked at the B- using FFT on the scope. Looked very clean.
Remember, you need four of those for the input stage. Probably heatsinks on the FET's as well. I could most likely build p2p gyrators smaller than that pcb, especially if not using a heatsink. Anyway, I'm not all that interested in installing gyrators and grid drivers in the mk6. I might hook something up externally because it's fun to experiment.
When listening to music I have my other amp.
Jan 20, 2018 at 1:29 PM Post #2,727 of 4,154
No need for heatsink. I have 4 of those pcs I used for other projects. They would fit nicely even with 4.
What are you using to read fft? Oscilloscope ffts are not designed for audio work.
Voltage doubler would probably work for you then.
Jan 20, 2018 at 4:03 PM Post #2,728 of 4,154
Yes, I realized there’s no need for heat sinks as the dissipation would be very low in the mk6
Yes, FFT on the scope is what I use. Range is from 1Hz to many MHz.
It would definitely fit inside if I take out the existing filter. Question is how the PT(s) would react to a doubler.
Jan 20, 2018 at 10:59 PM Post #2,729 of 4,154
Only the most expensive scopes have FTTs that aren't garbage, they are added to the scope as an afterthought. FTTs are process intensive, you need a dedicated audio spectrum analyzer to get a good reading, or at the very least a sound card. What scope are you using?
It may be easier to just look at the B- in AC scope mode. You don't need an FFT reading to know if the supply is clean or not.
They wouldn't. At the current you need the caps don't have to be huge.
