Negatron
- Aug 5, 2006
No disrespect meant, but your comments about the instability of the LDII++ output tubes is slightly mis-understood. The unstable tubes were in the LDII+, where the supplied Chinese tubes arced to the cathodes upon turn-on and Russian tubes solved the problem. Generally the stock tubes in the II++ are pretty stable. I've had several of both amps and never saw a problem with the II++. The primary reason for replacing the tubes in the II++ with Russian tubes is simply that they sound better as you mentioned. I might add that the heat issue is just that the heater regulators use the chassis as a heat sink and so the heat is normal and not an issue of concern. I'm just trying to defend a wonderful and cheap little amp whose own native language is only Music.
Originally Posted by Dept_of_Alchemy /img/forum/go_quote.gif That sounds like good news, the stock power tubes on the LDII++ are quite unstable and with the Russian upgrade 6S19P-V tubes even though the sonics improve quite a bit the amp itself still runs hot. EF92 and 5654 are quite rollable and gives a fair amount of room for tweaking the sound to your liking and doesn't cost too much to roll either. |
![wink.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/wink.gif)
