jonathan c
I have been using this
to condition the earpads on my LCD-X (2016 vintage). Great results from a small amount applied every two months
I've had the original LCD 2 that came out in 2009 for about 14, 15 years now and only thing I had to replace were the earpads, like all cushions not memory foam, eventually they fall flat. The wood still has no cracks and they work perfectly fine still.Mine are almost 2 years old and they're still good as new...no difference (as far as I can tell) in density and no aesthetic fading or bruising to the leather. In 5 years?...well I don't know, but I'm guessing they'll still be fine...
Blessings,
-J
EDIT: Oh I don't take any special care of the pads...i.e. leather conditioning, etc...and I use them almost every day for a couple hours so they've gotten tons of use in the past almost 2 years.
I have owned both the 2017 LCD-x and now own the 2021 revision. I think the 2021 is more refined and smoothed out some of the peaks and valleys in the frequency response. I don't have any issue watching movies on the 2021 without EQ, but wouldn't buy it if you don't have good EQ capability for music. I personally use Roon with several EQ curves that I have pulled off this and other forums. Once EQ'd, they are fantastic with excellent extension, dynamics and resolution.I would like to know if the lcd xc 2021 is a good upgrade from the lcd 2 fazor (2017). Im also using a denon d7000. The lcd 2 i have has this non fatiguing treble and warm dark signature i really like. Will the xc 2021 with proper eq be a similar signature
Anyone?Can anyone share an eq profile for the lcd xc 2021 with dekoni sheepskin pads
I bought the first of the 2021 lcd-X used without knowing about the mod. My one just missed out on the mod by a few weeks according to the build dateI have owned both the 2017 LCD-x and now own the 2021 revision. I think the 2021 is more refined and smoothed out some of the peaks and valleys in the frequency response. I don't have any issue watching movies on the 2021 without EQ, but wouldn't buy it if you don't have good EQ capability for music. I personally use Roon with several EQ curves that I have pulled off this and other forums. Once EQ'd, they are fantastic with excellent extension, dynamics and resolution.
I have the XC 21.Not for the xc
Hey so it’s better than just use destilled water??I have been using thisto condition the earpads on my LCD-X (2016 vintage). Great results from a small amount applied every two months
