I am at 200 hours on mine...plan to go to 400 hours for burn in. This was recommended by the Stax booth at CanjamAny links? I want to buy a nice one that does not break the bank, sub-$200. Also, how does it take for the Audeze LCD-X to break in?
LCD-X and XC Update
- Thread starter Audeze
RubbishThis headphone does not sound correct without EQ. If you are running it with stock tuning, you probably won't be completely happy with the sound characteristics.
Jonne Haven
I would totally jack someone wearing these outside....
Jonne Haven
It's official. The 30 day return period on my XCs has expired, I'm keeping them.
-J
-J
Rubbish
I put you on ignore. Sick of your ****in bull.
Ok, 10+ hours, now they seem to be breaking in!
Awe. Poor baby.I put you on ignore. Sick of your ****in bull.
I have been into audio for thirty years, had put over 500 hours on all of the headphones I've had, and had not experienced a "smoother sound" or "soundstage opening up a bit".I burn my headphones in, I have over 200 hours on mine and I notice the sound is smoother and the soundstage opens up a little bit.
I agree. And it's just in about every single post. He doesn't seem well versed in electrical engineering, or acoustics, and often presents his opinion, presented as fact. I do agree with most of his equipment choices, except for the last three; to the point where I had researched them thoroughly.I put you on ignore. Sick of your ****in bull.
Just expressing my opinion guys.
Physis
I am considering between LCD-x and Utopia. If I buy Lcd-x, I can buy one more headphone. Is Utopia worth it?
I currently own the LCD-X 2021 and the Focal Clear Mg. I have heard the Utopia in Carrollton, Texas, and that one had the best imaging and the best resolution I've ever heard from any headphone, only equaled by something like a HiFiMan HE-1000 or a Susvara. A beryllium driver will do this for you. Each track was presented with a scalpel like precision. The Clears are a better value for me, as I won't have a strong use case for headphones once I get back into a single family house. I find that you get diminishing returns over $2000: you have to spend a lot more money to get a clearly superior product. The Utopia is a "technical" headphone: its precision is not always pleasant to listen to, for some, as the notes are so sharply defined: some feel that a more warmed over, rounded, tube amp like presentation, is closer to what music is supposed to sound like. The Audeze headphones I've heard, definitely sounded more rounded, in comparison to the Utopia. There's new products that have come out over the past year at the Utopia's price point.I am considering between LCD-x and Utopia. If I buy Lcd-x, I can buy one more headphone. Is Utopia worth it?
Focal signature:
- lively
- balanced
- good dynamics
- small soundstage due to 40 mm driver
- a smack-you-in-the-forehead concentrated power punch of music due to metal drivers and that small soundstage that can be fatiguing at times
- better all arounder
- I like them best for female vocals and simple tracks
Audeze signature except for LCD-5 and CRBN:
- laid back, warmed over signature that some like for "cutting the glare"
- recessed upper midrange that can be corrected through EQ
- the dark signature still remains once you EQ to make it match the Harman curve
- average soundstage smaller than HD800S or Arya but larger than Focal due to 106 mm driver
- I feel that the Clear images better than the LCD-X, despite its soundstage (better placement within it)
- I feel that the dynamic driver offers better dynamics than the planar, in my case, noticing it the most with drums and loud rock guitar tracks
- I prefer these for complex wall-of-sound tracks, classic rock and EDM (making the most use of the planar bass)
Jonne Haven
Nothing for nothing but I'd personally rather have one Great headphone than two Mediocre ones.I am considering between LCD-x and Utopia. If I buy Lcd-x, I can buy one more headphone. Is Utopia worth it?
Blessings,
-J
Jonne Haven
LCD-X 2021 EQ Revision (06-28-22)
For more punch and slam
For those of you interested the EQ profile I posted in February it has under gone several silent revisions. The latest can be found below in the 19 band iteration.
And so for deep, tight bass that sounds more resolving and moves quickly out of the way of the honestly crafted mids and meticulously shaped highs, that accentuates the LCD-X’s "punch and slam" effect with kick drums and snares.
As you can see from the overlay-ed, inverted chart of Oratory1990's Harman Compensated FR (yes PEACE can do that!) I have stuck with a lot of his mids calculations, at times even more religiously than he did. My curve (green) deviates most from his (red) in the bass and the highs, adding a couple shots of bass slam and sparkling highs that makes vocalists more realistic and up close and personal. 80Hz is exaggerated in order target kick drums and make them cut through the mix. The dip after 40Hz is there to give sub, sub bass some slam to bass guitars.
Pre Amp: -14.35 (Be sure to enter this value to avoid clipping)
Band 1: Freq 40 Gain 3.45 Q 0.69 Filter Low Shelf
Band 2: Freq 40 Gain 0.83 Q 4 Filter Low Shelf
Band 3: Freq 80 Gain 5.12 Q 1.67 Filter Peak
Band 4: Freq 90 Gain 9.9 Q 0.65 Filter Low Shelf
Band 5: Freq 120 Gain 2.2 Q 1.41 Filter Peak
Band 6: Freq 220 Gain -3.5 Q 2.2 Filter Peak
Band 7: Freq 325 Gain 3.75 Q 1.2 Filter Peak
Band 8: Freq 450 Gain -1 Q 2.7 Filter Peak
Band 9: Freq 810 Gain -2.2 Q 2.41 Filter Peak
Band 10: Freq 1235 Gain -1 Q 2.4 Filter High Shelf
Band 11: Freq 1500 Gain 8.4 Q 0.71 Filter High Shelf
Band 12: Freq 1910 Gain 1.25 Q 5 Filter Peak
Band 13: Freq 2800 Gain -3.5 Q 2 Filter Peak
Band 14: Freq 3400 Gain 3 Q 2.1 Filter Peak
Band 15: Freq 5780 Gain -4.4 Q 4.8 Filter Peak
Band 16: Freq 7350 Gain -2 Q 7 Filter Peak
Band 17: Freq 10000 Gain -1.05 Q 0.9 Filter Peak
Band 18: Freq 13000 Gain 1.85 Q 2 Filter High Shelf
Band 19: Freq 19000 Gain 0.8 Q 0.8 Filter Peak
To increase or decrease bass, adjust gain to Band 4 to taste.
To increase or decrease treble, adjust gain to Band 17 to taste.
Here’s two original tracks of mine to try this profile out with that I mastered with the LCD-X 2021 that really pushes these cans to do things previously not thought possible by me:
Jonne Haven - “Big Bad World”
Jonne Haven - “Humble Me” (Norah Jones Cover)
It's been said already, but I must add that I've been working on EQing the LCD-X 2021 everyday for over 7 months now and I find that it responds to EQ settings superbly and with the greatest of resolution. Even the smallest of changes are reported, with minute detail and without distortion, the best of any headphone I have EQ'd.
Blessings,
-J
Blessings,
-J
Jonne Haven
I think it's the manner in which you're expressing your opinions that is raising a few eyebrows.Just expressing my opinion guys.
I'm curious as to your particular usage of EQ being somone who is not initially inclined to use it. You say you employ a modest bass shelf and it sounds good. I'm curious as to what a modest shelf is considered to be and where yours is placed. Would you mind posting your setting?
Blessings,
-J
