I would like to use it would my iBasso DX320 (4.4mm 7.1v) is balanced out. I also have an SPL Phonitor SE.
LCD-X and XC Update
- Thread starter Audeze
Just buy a 1/4 inch to 4.4mm adapter. A balanced dual 3.5mm (with locking connectors) to balanced 4.4mm headphone cable does not exist, as far as I know.
I want a 1/4 to 4.4 adapter cable. I'm having a hard time finding one.
Guy Fawkes
You are not found it because it is not possible to insert a single ended connector into a balanced output with an amplifier adapter without damaging it irremediably, this is possible if you already have a separate ground cableI want a 1/4 to 4.4 adapter cable. I'm having a hard time finding one.
Why not just buy a nice amp, such as the Gustard H16, and connect your DX320 to it. This will solve all of your issues with cables and adapters.
I have an SPL Phonitor SE with/ SPL DAC. And Topping 50 Balanced stack. I just want to use my new headphones in balanced mode.
You don't need a balanced cable. You have plenty of nice gear to connect the LCD-X to as is. Just enjoy the headphone.
I guess I just need to wait for them to break in. lol
This headphone does not sound correct without EQ. If you are running it with stock tuning, you probably won't be completely happy with the sound characteristics.
- Jul 3, 2013
Why dual 3.5 mm? These headphones use mini XLR on the cups, not dual 3.5 mm connectors.Audeze does not offer a dual 3.5mm to 4.4mm headphone cable. You can find them online. It will cost you around 60 bucks for a decent one.
Edit: I should have mentioned as well that the LCD-X has locking connectors for the 3.5mm connections. You will have to hunt around to find an appropriate cable, but a few are available.
I love Hart Audio Cables. Great System. I also have a couple of these great cables from ZMF.Where can I buy Audeze LCD cables that have a 4.4mm connection?
Guy Fawkes
it's very subjective, I love my LCD-X without any EQ
Andrew_WOT
- Jan 18, 2004
LOLThis headphone does not sound correct without EQ. If you are running it with stock tuning, you probably won't be completely happy with the sound characteristics.
Andrew_WOT
- Jan 18, 2004
For Pentaconn terminated cable try skyaudiocables, I have XLR terminated from this vendor, the best cable in my collection, superb build quality, ergonomics and look, reasonably priced too.
https://www.ebay.com/itm/Custom-Hea...XLR-Audeze-LCD-2-LCD-3-LCD-X-ZMF/174651279325
Total: 7 (members: 0, guests: 7)
