tdockweiler
The DJ100 is closer to the KSC75 sound compared to the Porta Pro since it has a titanium driver also.
You can demo the DJ200 (should be the same as the DJ100) at any Best Buy in the pro audio department.
That's what I would suggest.
The Porta Pro, UR-55 or KSC75 might be better for portable use unless you can use your Fiio E6.
The Porta Pro (based on memory) has less treble and more of a mid-bass hump. Probably worse low-bass extension but I'm not sure about that.
It really depends on preferences. The DJ100 should be more neutral than the Porta Pro.
I recently be a fan of Koss, and having tried the portapro and ksc75, I think koss' sound signature is really lovable.
then I see this! do you think I should return my portapro and buy this instead?
I'll use them on the go with my ipod nano gen 5 & at home with Fiio E6.
