Great info! I think I will buy a pair.
The OP said that a break-in period might be in order? I'm happy to burn these in for 50+ hours or more if necessary.
EDIT: Wow, long winded. Sorry, I was bored. Oops.
You definitely won't need 50+ hours for sure. I've owned about 7 or 8 pairs before and only two needed any sort of burn-in. I almost never burn in my headphones if they sound OK out of the box.
For a DJ100 I had once, I just shoved it in a office drawer playing music while I was sleeping. I'd loop my most obnoxious music (or pink noise) and crank it a little higher than normal listening volume (but not too high). I think I did this for 4 days and 8 hours each night.
I don't want to get into a stupid burn-in debate but the Dj100s I had that needed burn-in were actually rather muffled sounding, which is really bizarre. I only knew how bad it sounded because I had another DJ100 at the time. I seriously thought one of them was defective and complained about it in this forum. People tell me this is impossible. I guess it's just due to the Titanium driver or something.
I know some of my posts are rather ridiculous, but with my TBSE I can basically pick apart any change in my setup with ease. When I have a problem with my setup I'm usually able to detect it first on my DJ100/TBSE. When I was able to figure out the differences between the Modi and ODAC, it was much easier on the TBSE compared to my Q701 and HD-650. Why? No clue. Whenever I use a crappy source it usually sounded rather congested or muffled. I bought an old portable Sony CD player the order day for my DJ100 and it sounds awful with the DJ100. Apparently it's not one of the good ones but a more recent model.
I know it sounds nuts, but my DJ100 does sound slightly different on any single DAC or amp (if it has any coloration). I wonder if the KSC75 or even the OLD Pro4AA is the same way? I now believe that the DJ100 sounds the best on very transparent gear. It actually sounds even more balanced than before.
I have to admit though that for whatever reason, the treble is a bit harsh from the Ipod Touch 2G, but that thing sounds colder than the ODAC(!) and seems to have sort of edgy treble. I guess it measures ruler flat too or close.
I'm still loving it from my old Ipod 3G monochrome version. I'm trying to find the power output but all I can find is 50mw, but that seems way too high. I believe the newest Ipods are only 32mw per channel at 15 ohm. The Cowon D2 is 37mw at 15 ohm.
The Ipod 3G has just a touch of warmth, but the soundstage is nearly as good as my desktop DAC! It uses the WM8731. I wonder if the WM8741 sounds similar? That's in the Audio-GD NFB5. I swear that my Ipod Touch 2G can't possibly have a Wolfson DAC! Sounds nothing like any of the other Ipods. Just checked and I keept forgetting that it doesn't. Well duh.
BTW someone mentioned the upper mids. I still have always felt that they had forward upper mids. They're very similar in forwardness to my AKG Q701. Female vocals especially sound quite forward and never ever ever sound recessed. I think though that the nice thing about the DJ100 is they are never harsh and never have any sibilance. I think that is what Koss wanted.
Sometimes the DJ100 may sound as if it has recessed mids, but it's due to how a song is recorded and the DJ100 gets this right with the proper DAC. On some other headphones you can barely even tell. For example, vocals can randomly sound distant if they're supposed to sound that way in the recording. My Q701 and Dj100 fools me a lot.
Sometimes it's hard to figure out the Dj100's sound signature because it's so dang accurate to the recording. OK, with some slight forwardness in vocals, but not too much. Still accurate. The upper mids of the DJ100 reminded me of the SR-225i somewhat. I still can't understand why the graphs don't show them as having forward upper mids. Totally bizarre to me. You can easily hear them as being slightly forward. I can't even EQ up any range in the upper mids and treble without it ruining the sound. It is amusing when I use the EQ knobs on my receiver to increase the treble. They magically get clearer AND thinner sounding
Also, I remember in ljokerl's review that he mentioned that the mids become more forward with amping. I never really tested this, but it's possible. I don't think it would be due to any sort of coloration from the amp.
I wish I could be, but believe it or not I'm not a raving fanboy of the DJ100 from portable sources. I rarely even suggest them to those without an external amp. I always felt that they'd be best for those that already had a nice desktop amp/dac. I'm probably too picky really. I'm sure there are a ton of portable players that can make the DJ100 sound amazing. Someday I'd love to try the Fiio E12 or Jdslabs C5 with the DJ100. As long as i'm using a line out cable.
BTW does anyone else think the Sansa Fuze's line out is awful? I know it bypasses the amp, but still uses the DAC. Headphone out to amp sounds waaay better and it's doesn't sound like it's adding any distortion. Generally "double amping" is a big no-no, but it never sounds that bad to me.
Oh yeah, sometime I'd like to try the DJ100 with some ridiculously expensive gear and see what it's like. Probably exactly the same, but maybe not. Sometime when I get more money I want to try the Bifrost. I have a feeling the DJ100 might sound awful with the Lyr, but who knows..
I'm trying to squeeze an even larger soundstage out of my DJ100
For my DJ100 once you have a good enough amp, the DAC is the most important part IMO. I really like the Modi for the DJ100. I even sold my ODAC because I liked it so much!
