Sadly your numbers don't jive w/ the sound in this case. The KGSSHV rocks the 950 in bass response and dynamics compared to the E90. It's not even remotely close. E90 is thinner and more flacid compared to the punch and richness of the HV. Sounds like you are measuring the wrong thing to me.
all else being equal: "flat" amps, same headphones, the main determiner of relative perceptual frequency response balance is loudness - look up Fletcher-Munson curves
if you don't measure you don't know if you have matched SPL, "sounds the same loudness" with seconds of switching time won't get you even 1 dB "by ear"; 0.1 dB SPL, ~ 1% V match is required for rigorous subjective comparison
measurement is the only way to establish this minimum necessary condition for valid subjective evaluation - for ES amps direct V measurement isn't easy the output V, impedance makes special lab equipment necessary
cheap SPL meter accuracy is poor, reproducibility may be adequate, better than ears anyway - the positioning on the coupler gives more variability - don't move/remove the headphones on the coupler, just switch the amps back and forth until you get the volume settings that give equal SPL
of course blinding is also necessary to make sure the only info your brain is using is the sound reaching your ears
all of the above is a big threshold for subjective evaluation to meet so I do think reasoning from the published technical specs of the amps is likely more reliable for perceptual prediction in this instance
there is still the possibility that the E/90 has inadequate input coupling C - that I can measure, tweakers could easily upsize the caps - Koss isn't clear in the specs if the "8 Hz -35 kHz" includes the amp
I don't know how much to rely on purrin's measurements without more info on the setup, measurement details
old Stereophile review has specs - don't see why they would have changed:
Description: Electrostatic headphones with separate energizer unit. Frequency range: 8Hz–35kHz (no tolerance given). Sensitivity: 104dB at 100Vrms differential input at 1kHz. Diaphragm thickness: 1.5;um.
E/90 Energizer/Amplifier. Frequency response: 1.6Hz–50kHz ±3dB at 100Vrms differential output. Input impedance: 100k ohms. Input level: 1Vrms for full output. THD+noise: 0.001% at 1kHz and 100Vrms differential output. Voltage amplification: 60dB. Channel separation: 80dB at 1kHz, 100Vrms differential output. Audio output voltage: 600Vrms differential, 2300Vrms push-pull with soft limiting. S/N ratio: 100dB at 100Vrms output. Bias voltage: 600V DC.
