Hey fellas , I've been using soundmagic ES18 earphones for more than 1.5 years ,now want to upgrade to some better ones . Please suggest a below $9 KZ earphone as good or better than Soundmagic ES18 .
Friend has this KZ earphone which looks edr1/edr2/KZ SE.(All looks same) (
https://www.aliexpress.com/item/Original-KZ-EDR...)
but it is not as good as soundmagic ES18 in terms of comfort and sound clarity. have hard time adjusting it , becomes very irritating to wear and does not fit properly in my ear with all sizes of eartips provided on the other hand soundmagic es18 medium size one's perfectly fit easily tight without any problem.
Top priority is Very good comfort , very good Clarity and good bass as i listen a lot to EDM’s .
I WANT TO BUY ONLY FROM ALIEXPRESS as i have some discount coupon on it.
There are so many sellers of KZ and so many models that i actually don’t know which is reliable one and can go on for at least 1.5 years and provide onpar performance to ES18 with as good as comfort wear , better sound clarity and on par sound quality.
I'll using earphones on Mi Redmi note 3 with viper4android and on Laptop .
