CardigdanWalk
Update on TRN Bluetooth receivers, I have both the TRN BT-3 and the new TRN-BT10.
Both seem to have very similar specs and use he same chipset, I think the later is IP-7 waterproof and Bluetooth 4.2
The BT-3 is bulkier, but at the same time feels more substantial and less likely too break.
The BT-10 if a lot more flexible, so easier to roll up, but also feels like the wires would be more vulnerable over time.
For me though the biggest issue is the positioning of the control / battery / mic
On the BT-3 it’s built into the plastic and held against your neck, so more solid but your voice will probably be fainter.
With the BT-10 these “dangle” beside the side of your face, so I’ve no doubt mic wise it will be better for talking.
However my primary use case is running, and I think it looks a bit stupid with these two black dangly earring style boxes beside my face, which I’m sure will start brushing against my face as I move.
So for me, BT-3 wins. (And is annoying as I have the non-aac version, so I should have just bought that instead of gambling on the BT-10!)
