skeej
What's some good and cheap portable dac/amp to get for zs5? Using it on my android phone (oneplus 3)
Not sure if you'd notice a lot considering the biggest bottleneck in terms of changing the sound are the ZS5 by themselves by a mile, but I guess you could potentially benefit from at least getting a <2 Ohms output impedance to reach sufficient damping. Fiio A1 would do. That's just an amp, not a DAC. I really don't see how upgrading from the already sufficient OP3 onboard dac would get you any gains, but if you'd really want to try you could go for a Fiio K1 for instance. It probably won't work on a vanilla OP3 ROM. Verify which custom ROM has support for running the K1. Other options for just amplification are a good version of a CMOY amp (for instance the JDS Labs one) or the Topping NX1, if you can still find it. Not the NX1s considering its output impedance being already too high for 16 Ohm headphones. I'm not sure about the NX1a, can't find output impedance info on that.
