actorlife
Zare maybe the source you have them on? Maybe try other tips. Did you have other players to see if there is a difference? If not try pink noise and music at your listening volume for about 80 hrs.
Hi, I'm choosing between the ZS3 and the ZST ($2 price difference on AE) for my first KZ headphones, and it's safe to say it will also be my first proper audiophile pair, considering my past headphones were Coloud's Pop and Boom. I'm only gonna be using it on my phone with Viper4Android and Dolby Atmos. Is it worth it to get the ZST for $2 more or I'm better off with the slightly cheaper ZS3? And is there any difference on the sound quality of ZST carbon and candy edition?
This might help
The ZST is 'audiophile' better clarity and quite a sharp treble that some say is too sharp. The ZS3 is a lo-fi hero is great with poor recordings, what it lacks in detail it makes up with in terms of musicality. Buy one now the other next month, it's the head-fi way![]()
I don't recommend the ZS3, it sounds "confused" to my ears. The bass bleeds into the low mids and there's some chops in the FR. The ZST is clearly a bright IEM and I know no alternative on the price range, whereas the ZS3 is bassy and there's better alternatives on the cheap like hybrid pistons or sony mh1.
The ZS3 without stock filters are much brighter and bass is 30% less heavy so no more bleeding into mids.
The red stock filters are too thick like a sort of rubber, that's why it increase the boom room effect in a way it can be annoying for some of us, taking the stock filter out with a needle is the mod to do to have non-basshead configuration, that doesn't mean you will not have enough bass, the bass quantity will still be high but not bleeding or hurting your ears
Damn it. the ZST price went up $5,I guess I'll get the ZS3 now. Is the ATR really that bad? They're half the price of the ZS3 though. I've read that the ZS3 is similar to the ATR but with more bass.
The ATR need BI time about 80hr before they shine. What gear is it going to be hoooked up to? ATE is great too. Check ebay as well.
Just on a phone with Viper4Android and Dolby Atmos.
