Mus1c
- Dec 15, 2016
yes that really true it hurts that part of my ears i only got to listen to this iem just litlebit of time and they're to bulky and hard.
Ok tested again this time with Flac and 320kbps songs.
Obviously the bass is much lower now, the boom room effect is totally gone!!
Though the problem now is that treble (highs) are too harsh now, you will definitely need to decrease them with an equalizer.
I replaced the red filters with the Hifiman ones, it didn't change the sound at all but now it's protected against dust and dirt.
So to conclude: With the red filters the ZS3 are too boomy with a very slight harsh highs for people who aren't bassheads the fix is to use of an equalizer to reduce bass and slightly treble.
Without the red filters, bassheads will not like it because they will loose the full boom effect so this mod is non-sense to them, but for others they will still have to use an equalizer to reduce even more treble but they can keep bass untouched this time.
See how transparent are the Hifiman filters while the KZ are thick
Glad you like them better. The treble is gonna smooth out with time used. Where do i get those hifi tips? Got a link?
I have them from the Hifiman RE 262 box (got them 4 years ago)
Dunno if you can buy them on aliexpress
Why not doing some holes in the red filters?
well not ed3 and wat it is then?OH. Got a package on the table could it be the KZ ED3? Will report later.
EDIT. Its not the ED3 s. Whoa these are in the same league as the ZS3 perhaps better and more comfy. Played a bunch of gens and they are versatile. Jazz Pop Classical Latin amazing sq and truly out the box sounds great. Might do some music over night to see if they sound any better. I like the plug alot and the rope type cord. BASS is amazing and does not overpower anything. These got here quick from China.10 days dang fast. Guess the iem?
About the treble, I just burned the ZS3 at max volume for 4 hours yesterday on my Cowon J3, tried them again on my HTC 10 it was indeed smoother, then I chose ''Other'' instead of HTC studio earphones in the Boomsound menu and the treble is nearly perfect now!!! No need for an equalizer anymore.
Bass is high enough for my taste, deep and detailed and boomy when it should in some songs (not like before creating a fake boom room effect with any song), mids are finally liberated as bass doesn't bleed in anymore.
Will give it more time, but from the sound of it this mod is the one you should do if you are not a basshead and want to enjoy your ZS3 to the max
Anyone know how remove the memory wire on the zs3?.
Glad they worked out for ya. NOW get the Rock Zircon and be even more content.
The MEMT X5 are nice too. They rank right up there with the Zircon.
can you give step by step? Or picture of walktrough to remove the wire.Very slowly & carefully so you don't nick the actual IEM wires.
The memory wire is just a piece of thin bendable solid wire in a piece of heat shrink. You can use anything that cuts to snip through the heat shrink, from your teeth to a razor to nail clippers.
