What is the star-8 cable? Not so simple to find it using simple google search, I remember also
Looking for a star-87 cable once with no luck
Thanks all for the helpful insights. My biggest reservation is the gain issue, since I have the sr1a and don’t like the idea of having to drive my CFA so hard. Also the Ti-1b box is quite a expensive right now.about right with the ca-1a but not the sr1a which requires far more gain
Raal's new upgrade silver headphone cable for both CA1a and SR1a to be used in conjunction with TI-1b or Raal's direct drive amps.What is the star-8 cable? Not so simple to find it using simple google search, I remember also
I think it depends on your CFA3. I can drive my SR1a with the CFA3 via the Ti-1a box with about 10 times more headroom than I would ever need. (Listening to it right now, at 8 o'clock).Thanks all for the helpful insights. My biggest reservation is the gain issue, since I have the sr1a and don’t like the idea of having to drive my CFA so hard. Also the Ti-1b box is quite a expensive right now.
I have a solid CFA unit but no speaker taps, purely an xlr based amp. So I believe I would need the ti-1b. Running the abyss TC on my unit I tend to run at 10 or 11I think it depends on your CFA3. I can drive my SR1a with the CFA3 via the Ti-1a box with about 10 times more headroom than I would ever need. (Listening to it right now, at 8 o'clock).
By TI-1a I meant the first version of the TI-1b box, but in the metal enclosure instead of the new polycarbonate enclosure used with the TI-1b. My TI-1a connects to the XLR out, not speaker taps like the resistor box. As far as I know, the TI-1a and TI-1b are identical internally--the only difference is the enclosure. (In fact, if you look at RAAL-requisite's website listing for the TI-1b, it refers to the TI-1a throughout, presumably because they just haven't updated it yet: https://raalrequisite.com/product/ti-1b/).I have a solid CFA unit but no speaker taps, purely an xlr based amp. So I believe I would need the ti-1b. Running the abyss TC on my unit I tend to run at 10 or 11
thanks for the info, that’s really helpful. Also nice to know I can hunt for the 1a as wellBy TI-1a I meant the first version of the TI-1b box, but in the metal enclosure instead of the new polycarbonate enclosure used with the TI-1b. My TI-1a connects to the XLR out, not speaker taps like the resistor box. As far as I know, the TI-1a and TI-1b are identical internally--the only difference is the enclosure. (In fact, if you look at RAAL-requisite's website listing for the TI-1b, it refers to the TI-1a throughout, presumably because they just haven't updated it yet: https://raalrequisite.com/product/ti-1b/).
has to be an attenuation issue because with mine out of my chord dave and sr1a I am around 3 o clockI think it depends on your CFA3. I can drive my SR1a with the CFA3 via the Ti-1a box with about 10 times more headroom than I would ever need. (Listening to it right now, at 8 o'clock).
I missed that you parted with. Honeymoon couldn't last. It's why I didn't bother. Well, in part, mostly because I'm too happy with things as they are.I had the CA-1A with the TI-1a interface that I used with my CFA3. If memory serves, the CA-1A needed approximately the same amount of gain (within 1db or so) as the Susvara for the same db. Plenty of headroom in my use case and didn't leave me wondering if I was getting the best out of the CA-1A. Ultimately they went to the market, as I wasn't reaching for them very often and hoarding headphones isn't my end game.
I never dabbled with the SR1a so I figured this was a way to kill my curiosity for the essence of it and the CA1a in one take.I missed that you parted with. Honeymoon couldn't last. It's why I didn't bother. Well, in part, mostly because I'm too happy with things as they are.
I believe you got the gist as they both follow the same traits and are specialty presentations. I hardly ever listen to the SR1a for enjoyment.I never dabbled with the SR1a so I figured this was a way to kill my curiosity for the essence of it and the CA1a in one take.
