Do our CFA-3's have a fuse in the PS and if so has anyone tried an audiophile fuse to see if it made any change?
KG CFA3 headphone amp
- Thread starter RudeWolf
All my amps use fuse. 5x20mm size. The fuse tray is accessed externally, it is on the IEC inlet. There is a small tab that can be pried open with a flathead screwdriver and the tray should pop out. 2,5A rating for 230V and 3,15A for 115V. Slow blow.Do our CFA-3's have a fuse in the PS and if so has anyone tried an audiophile fuse to see if it made any change?
Thanks for the info..... Has anyone tried one of these SR Purple fuses in the CFA-3?All my amps use fuse. 5x20mm size. The fuse tray is accessed externally, it is on the IEC inlet. There is a small tab that can be pried open with a flathead screwdriver and the tray should pop out. 3,15A rating for 230V and 2,5A for 115V. Slow blow.
kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
brianfromspace
Hi @Dukei, do you still build the CFA3 for people interested? I am for my current hungry DCA Expanse.
Sound Eq
- Nov 9, 2013
is cfa capable to drives susvara properly
how is cfa3 compared to enleum with susvara
paradoxper
Seems like this could have been like an uberamp3.a new year teaser
sanken output transistors.
with a big enough power supply, capable of 25 amps.
yes the power supply will be switchers designed for class D amplifiers
kevin gilmore
- Jun 21, 2001
uberamp2 is good for 500 watts into 8 ohms. and is a true cfa amplifier. not zero feedback.
paradoxper
Always the nth degree.uberamp2 is good for 500 watts into 8 ohms. and is a true cfa amplifier. not zero feedback.
What's the output proposed for the new teaser amp?
kevin gilmore
- Jun 21, 2001
it will work with power supplies from +/-24v to +/-45v.
with +/-40v power its 100 watts rms per channel into 8 ohms.
subject to suitable sized heatsinks and power supply
I do love the CFA3 driving my 74dB/mW K1000, this combo is getting more and more headtime and it gets very loud at about 12-13 o'clock, and it's foot tapping all the time. Maybe on my previous coment I suggested I wasnt getting enough volume with classical, I should further clarify I may have put too much emphasis on those 3-4 test albums where the recording is exceptionally low volume. Other then those, even the average classical recording gets plenty low at around 12is cfa capable to drives susvara properly
how is cfa3 compared to eneeum with susvara
I heard the Susvara and HD800s on the Volot (rated 16W at 32ohm), then the 800s on the CFA3 and prefered the CFA sound signature (this is admitdly on different systems and short listens on the Volot, so dont quote me on this). All that said, sorry but havnt listened the Sus on the CFA.
paradoxper
And so do I need another amp.it will work with power supplies from +/-24v to +/-45v.
normie610
count me inAnd so do I need another amp.
jlbrach
- Jun 4, 2005
there is no HP that the CFA3 cannot driveis cfa capable to drives susvara properly
paradoxper
You were supposed to say no.count me in
