khaos974
- Mar 19, 2008
THat's why I wanted to make sure, if they sound that good with an added ipod-DAC + ADC stage, they should sound even better with a direct SP/DIF or USB input which I hope there will be.
Does it come with a battery? If so will it be replaceable because I would expect this product to last longer than the 3 years I'd expect from a more normal portable headamp.
as has been stated already though, everything inside the jh-3a amp is done digitally until it get sent to the amp. if you input analog the first thing that happens at the input is that it gets run through a ADC, thats why a external dac to use with it is a waste of time and money, and that one should always feed it with a digital signal if you can.
