Poimandres
- Dec 23, 2009
Where are you from I have had quite a few impressions done and only 1 has ever come out perfect. If you are close to NYC you should call Dr. Beth Orliss.
That sucks man. I guess that's the big downside of buying customs. No guarantee that the fit will be right the first time around, as so much is dependent on how well your impressions were. Maybe your audiologist offered you a fit guarantee? If so, you might want to get another impression done.
And funny enough, that sounds like it's the same spot that's hurting my ear. By the tragus, but a bit deeper, closer to the opening of the ear canal. It actually hurt really bad, two days later it's still a bit sore. Really weird.
I no longer use the impedance cable. Changed amp. But I feel like having used it the tuning of the jh13 has changed.
you just got used to the modified sound. be sure that the most changing element in our audio system is always us ^_^. adding or removing a resistor in the path isn't going to leave a print into the jh13.
but as said above, using an impedance adapter will change(while you use it!) at least the signature of pretty much any multi BA IEM. for some it's very obvious, for others you might never notice the change, but there will be change. and only in very few occasions can you hope for the sound to become more pleasant with more impedance at the source.
I find that about 5 ohm can be ok (old jh13), but past 30ohm I don't like what the sound becomes. I don't know what amp you have that goes too loud, but then I would advise not to use the amp at all, or to get one with low gain settings for your jh13(often you can just ask the manufacturer when you buy the amp and he will set whatever gain you like). adding resistors is a cheap and most likely bad solution and in my opinion given the price of a pair of JH13, it's a little late to go "el cheapo" way.
I use mine as is on a few DAPs. and when I'm bothered by the hiss of one source, or really feel like the source isn't good enough for the JH13, then I add my UHA760. one of the gain setting is -12db, that's low enough to give you plenty of room for any IEM, and digital control of the volume makes sure that there is no channel imbalance at any position of the volume knob.
if you need small and long lasting battery you can go with something like a pico slim. (also digital control of the volume so you don't have to fear channel imbalance).
and even for desktop amps I'm pretty confident you can find someone who will make you a negative gain setting of your liking.
Loving the pairing of my jh13fp's and the calyx M.
