JH Audio JH-13 PRO impressions thread
ear imprint : " open mouth " or... closed mouth ??
I did it ! I just took advantage of JH's black friday sale
Now... I need to have a nice ear print done !
QUESTION: it is mentioned to do the ear imprint " open mouth " !
But... I am not a rock star, so, I don't sing or even talk when I use my IEMs. I just use my IEM to listen quitefully to my music.
--> So, should't instead make the imprint in the same position as when I will use the IEM ? : relax in a sofa, with the JAW relax and teeth not joined but lips closed?
anasztasia
- Jun 11, 2013
Congrats man you will not regret it!!
I did my impression while biting a small white block the whole time. Note that I am not a rockstar either
And i got it right the first time around, so i say do exactly what they advise on their webpage.
Hooe this helps
Hooe this helps
Finally decided that it was time to replace my JH-13s, the sale was too good...mockups of my in ears
Girls Generation
- Feb 7, 2010
Please do open mouth as to make sure the shells will accommodate your ear canals at its widest position. It won't matter if you don't sing, it'll just yield you a higher chance of having a nice seal rather than a loose one. Note that bite block is required.
Ok i understand that by doing so, the IEM Will be a little bit "larger" inside the ear. But... by doing so, don't I risk to have it hurting or at least inconfortable when i wear it with my mouth closed ?
Girls Generation
- Feb 7, 2010
That will never happen unless the molds get deformed. The only risk is that it might be TOOO tight in which case your canals will adjust, but that doesn't usually happen with acrylic shells.
Trust me I've done impressions atleast 20 times and I got the perfect ones with JH at the moment. 2nd pair and perfect again.
Thanks a lot for those advices.
- Mar 29, 2010
Hi Guys,
I'm in the market for a DAC\Amp as I am going to be setting up a home rig - any suggestions for gear to compliment my JH13 FP (and future Cans).
Thanks
Thanks
Girls Generation
- Feb 7, 2010
Hi Guys,
Thanks
There are so many kinds of gear that it's hard for anyone to give any sort of helpful suggestions. Maybe if you could list your preferences such as physical size and portability, how much SQ matters over all else, your budget, etc. it'll make it easier for anyone to speak up and suggest something.
Hi Guys,
Thanks
PM sent
- Mar 29, 2010
I know - you would think that after all these years of being on Head-fi, I would know better lol
Ideally I am looking for a Desktop dac\amp to plug into a PC which will be running XBMC to play music through.
The connector to the dac\amp will need to be Optical or USB
I am happy to consider separates or All-in-one DAC\Amps
SQ is very important as I will be initially using my JH13 and am also considering HD800 and TH900 cans in the future.
I know that ultimately I will probably only use Cans with my desktop rig, but initially I will be using my JH13
Whilst I like "warmth", I tend to be a resolution junkie ie I prefer my JH13 way more than my 8A (must get around to selling them)
My budget would be up to $600 per unit or $1200 all-in-one
....oh and aesthetically pleasing would be nice (ie I like the look of the Woo WA7 Firefly)
BTW - even after all this time I am still struggling to understand how impedance\resistance\voltage etc.. fits into choosing the right amp....so if anyone can give me a real dummy\idiots guide to how it all works\fits together, it would be appreciated
Thanks
goodvibes
- Dec 28, 2009
Hi Guys,
Thanks
What source? If it's a PC, I would look past USB and get something with a firewire interface from TC Konnekt. Their Dice II chip is still the best clocker I've heard from a PC and they're cheap. Their headphone and DAC portions are better than they used to be and VG now but the dig out is fab.
- Mar 29, 2010
I'll have a look at your suggestion of the TC Konnekt.
I'll be using a cheap PC to act as my media centre using XBMC. I was looking to feed the digital signal via USB\Optical to a good external DAC\AMP
Girls Generation
- Feb 7, 2010
Why not look into something like Light Harmonic Geek Out, or Resonessence Herus? No need to spend crazy amounts of money for minimal improvement that you might most likely not even be able to appreciate unless you're analyzing the music, not listening to it.
ps. No context. I may look into this TC Konnekt as well.
Total: 6 (members: 0, guests: 6)
