dallan: thanks for the response, I guess frustration/bewilderment doesn't translate easily on the internet. As far as I can tell, 3X0 and I have tried some of the "higher end" amps with a JH13 and have found ourselves unconvinced that there is a difference, or a large enough difference to warrant the cost (in my case, that depends on the amp).
Glad to hear that you found the O2 great. I lean more and more towards buying one each day; if only I could get someone to help reposition some of the jacks...
You did try the O2 with the JH13, right? Your sig indicates you no longer use the JH13. Why is that?
