3X0
- Sep 2, 2006
I don't think the price of a cable changes ones hearing and I can certainly here the difference, what your saying is like people would like the UE18 over the JH16 because the latter is more expensive but that is not the case. I trust me hearing and if I thought a $10 cable sounded better then I would use that.Every single person I have read of here that has tried or own the piccolino has clearly said they preferred it over any of the other cables the have heard so this is not just me saying it.Anyway I will be taking it to the meet so will see what other people have to say.I also have line out docks and other interconnects that are made of pure 24k solid gold wire but I still prefer ones less then half that price.
Price-quality associations exist whether you believe yourself susceptible or not. The fact that you're even aware of them actually suggests that you're vulnerable to them. Sorry, but there's no way out of this one.
The good news is that it doesn't affect your personal perception or appreciation of the cable -- no one can tell you what to think, and it's clear that the Piccolino cable sounds a cut above the rest (for you and the other owners you mention). This is really all that matters.
Blind test isnt answer to everything, you can found blind tests where rig costing 500$ sound same as rig costing 12K$, maybe if we do blind test comparing JH13 with Sennheiser CX300 with custom tip, we will discover that they also sound same. I dont use blind test and I dont believe in results of blind test.
Those types of controlled blind tests are legitimate if the transducers (speakers, headphones) involved are the same. However the JH13-CX300 comparison is a poor example -- transducers produce almost 100% of the difference in headphone-listening (in speaker-listening, it shares importance with room acoustics and treatment).
