Lotoo Paw Gold Screen Replacement & Servicing
The screen required can be found by searching for "1.77 inch 45Pin OLED Screen".
There are 2 types of screens which come up for this so make sure that it is the one with the narrow connector and not a wide one ie.
If you don't have a clean room you can work in, you can undertake the required work in a bathroom after running hot water. The moisture in the air reduces the amount of floating dust the inside of your electronics may be exposed to. The same is true if you have to apply screen protectors.
In the absence of both of these, keep a cotton bud to hand to wipe away any dust which settles on your screen or the inside of the sapphire glass.
To replace the screen follow these steps:
Simply do the reverse of the above steps to reassemble the player.
My screen had taken on a washed out view with ghosting. The results aren't so clear in photos but the difference is apparent nevertheless;
With respect to the battery, there only appears to be one manufacturer for the battery used in The LPG and the exact battery can be found on their site here:
http://www.serui-battery.com/Lipo-595080-with-BQ27200210-111.html
Unfortunately they only currently deal with bulk commercial orders, not individual consumers however I've put in a query through one of my companies and will update when I get some information regarding minimum orders and pricing. I've not found any consumer resellers for the battery as yet.
Hope the above is helpful. Any queries, let me know.
